Thanks to ALL for your help!!
First Newman machine - Big Back Current Spikes lighting up Incandescent bulbs
Started by hartiberlin, March 31, 2018, 07:03:09 PM
AlienGrey
Stefan an interesting film but perhaps not the best way to go about giving it away, he could have done kits on a smaller scale and sold them on the internet instead of arguing with idiots because you can never win when you argue with an idiot.
PS Have you got the rest of the circuit ?
hartiberlin
Here is now my video, which I recorded, when I visited Mr. Newman in 1987 in Lucedale, Mississippi in his workshop in the woods there on his property.
https://www.youtube.com/watch?v=Fi8FbMHNc8Y
Hope you like it. Please also read the comments below this video. so you will understand more...
Many thanks.
Regards, Stefan.
Belfior
Quote from: hartiberlin on April 04, 2018, 01:58:15 AM
Many thanks.
Regards, Stefan.
aah there is my other anti-grav idea presented by mr newman. So it seems it works to some extent! Nice video!
hartiberlin
Hmm, maybe I was wrong with my last rumblings....
Russ has now put out a new video using his 2 partitial coils
inside his coil and comparing the current and voltages in it, when he shorts
out the different partitial coils...
Very interesting:
https://www.youtube.com/watch?v=tPLbJYkWhCw
Also he found Newman´s patent,
https://worldwide.espacenet.com/data/espacenetDocument.pdf?ND=4&flavour=trueFull&locale=en_EP&FT=D&date=19830317&CC=WO&NR=8300963A1&KC=A1&popup=true
where it is also claimed that
Newman used 2 coils on his very first  big machine, where he was able to light all these
incandescant light bulbs and had more electrical energy out than in...
( which by the way he only could mainly show on the very first big machine and never
showed on later models... there he only used these FL tubes which only killed the energy of the sparking...
So all in all, it seems to be very important to use 2 different coils in a Newman machine design, one which thick diameter wire is the inner coil and a second one with small diameter  wire as the outer coil, so you have some kind of a transformer process going on while the magnet is rotating ..which I also did miss in all my tests,
as I only used one coil for the machine.
No wonder I never got these long lasting back current spikes, as my commutator was only pulsing and reversing the one single coil....
Now the question is, if Newman used also a second commutator for the 2nd coil somehow or if this was just a passive pickup coil just directly
connected to the incandescent light bulbs ?
Too bad I did not film this better in my visit, but time there was so much limited and Mr. Newman just only wanted to show the small toy and fan motor...
Now I have to look up, if I will find some better pictures of the first big machine, that will show the commutators better there within it....
Regards, Stefan.
hartiberlin
Also I guess we need 2 commutators, one for the inner coil and the other for the outer coil  to check out,
how these 2 coils can support each other and how the current can be fed back or shorted out at the right position of the rotating magnet
and to see, if you could get then a bigger back current spike...
Regards, Stefan.
