HHO Water Hammer Generator By Tommey Reed
Started by TommeyLReed, April 14, 2018, 05:36:26 PM
TommeyLReed
Hi All,
Still working on a few projects and experimenting.
I like to offer this simple design to use HHO as a added fuel for a water turbine generator. This will create a water hammer effect.
This system is basics with a 60psi/1000gmh water pump. Using a pelton wheel design to power a 48v 1000w bicycle hub motor to charge a 48v battery bank with a 2500 sive wave inverter to power the pump.
russwr
John W. Keely of Philadelphia Pa, made an actual water hammer hydraulic rotating motor unit  back in the late 1800's. It was shown with power take off crank running a saw, sawing wood. Self contained. Free energy. The US Patent application was stalled since the money investor's names were not on the manuscript submitted. The all brass unit with 4 way rotating shock valve generated 50lbs internal pressure to keep the balanced flywheel going. ( spoked + heavy metal rim type is best) About 15 years ago, another free energy water hydraulic unit was built and tested in Africa. Years ago I saw in NY, a self running air compressor with no battery, wires, or motor. It had an adjustable vortex tube that inreased the tank's 40lb pressure to keep the main shaft going with air cylinder. Inventor was mowing lawn with long air hose out the window to spark plug hole fitting.
kolbacict
That is, an outbreak of HHO will first cause an increase in pressure and the release of water to the turbine. And then a decrease in pressure, which will suck in a new portion of water?
Dog-One
Quote from: kolbacict on March 12, 2023, 03:04:27 AM
... suck in a new portion of water?
I think kolbacict is correct Tom.  You probably won't need the water
pump if you keep the splash pan fairly close to the blades.  Maybe
only a small make-up pump at the most.  Unless your planning on
using the suction to bring in the next charge of HHO gas.  As I recall
though, following the expansion, the contraction happens extremely
fast, so your pipes will need some volume to move things quick
enough.
If you are going to be making HHO in a standard cell, having vacuum
on the cell will greatly increase production rate--I'm just not certain
if the gas you will get will all be HHO or if some of it will be water
vapor.  Could be some water vapor is a good thing.  You'll have to
try it both ways and see what works best.
Paul-R
I don't know how big the combustion chamber is but if it contains pure stochiometric HHO under pressure, I would venture a guess that it may well blow the apparatus to pieces and render everyone around stone deaf.
As Patrick, Bob Boyce and others have stressed, HHO is very dangerous.
