Calculated COP=10 Active Antenna System
Started by panyuming, April 26, 2018, 06:32:36 PM
panyuming
Quote from: kampen on April 29, 2018, 11:55:23 AM
Oké......[size=78%]and how can we replicatie built this?[/size]
Thank you kampen
I do not recommend testing this circuit because it may not meet CCIR regulations.
This is a OverUnity method that can be proved by conventional calculations to obtain energy from the earth.
I hope everyone will develop a more practical method based on the principle of "charge incentive."
panyuming
Quote from: Collapsingfield on May 01, 2018, 04:07:12 AM
Don't forget that the diode will kill the effect. Before opening it is a small serial capacitor with an inverse voltage eq to collector cap and after every step it will be harder to open it and the impedance will be high till the opening.
In the past, there were many people using radio receivers and fewer people used radio transmitter. Now almost everyone uses a mobile phone, and they are all using radio transceivers.
Because the radio is receiving radiation energy from a broadcast station, receiving the program on the radio does not affect the radio energy received by the radio regardless of how much voltage is placed on the battery.
The same is true for radio transmitter. It emits radiated energy. No matter how the radio's ground wire, series battery or capacitor, or the voltage in the capacitor is high, it does not affect the radiation of the antenna.
Therefore, the diode's turn-on voltage (0.3V~1V) is insignificant for the 100V voltage accumulated in the capacitor.
panyuming
The energy of the transmitter's internal battery is converted by the transmitter to high-frequency energy to radiate from the antenna.
At this time, the antenna will have 'antenna high-frequency current'. Similarly, the corresponding, symmetrical, must have the same quantity 'ground high-frequency current'.
panyuming
The higher the frequency of the radio transmitter, the shorter the antenna, the shorter the ground wire, or the smaller the area of the ground metal plate.
If the principle of this post is used, the high-frequency power amplifier IC in the mobile phone can obtain the ground energy, and the mobile phone can become a self-powered OVERUNITY device.
forest
Find one Tesla GB patent (don't remember now the number) , and also his radiant energy famous patent and compare. You are right, except there is slight problem - the receiver should not load transmitter and that's what Tesla found.
