Calculated COP=10 Active Antenna System
Started by panyuming, April 26, 2018, 06:32:36 PM
ramset
panyuming
COP 10 is quite a Bold statement
I do appreciate your sincerity,   having spoken with some antennae builders here.. your explanations seem to need more clarity ?
Are you suggesting that it takes the transmitter to engage an "OU gain" which comes from the ground ?
seems a simple experiment can be modeled [By you ... so we get it correct ?]
example
what frequency
best Antennae
what type transmitter
good clear schematic
should ground be ??[treated or ?]
very qualified Builders here are ready to try this, but resources in the open source community are limited and spread quite thin ATM.
respectfully
Chet K
Thanks Grandma
panyuming
Quote from: forest on May 02, 2018, 07:37:05 AM
Find one Tesla GB patent (don't remember now the number) , and also his radiant energy famous patent and compare. You are right, except there is slight problem - the receiver should not load transmitter and that's what Tesla found.
Yes, there are no receivers in this plan. Thank you!
panyuming
Quote from: ramset on May 02, 2018, 03:52:25 PM
panyuming
example
what frequency
best Antennae
respectfully
Chet K
Chet K Thank you very much! And thank you very qualified Builders are willing to experiment with this plan.
I'm not suitable to post pictures in this forum.
So I will reply to your detailed content written in the Chinese website, please see the following website: Thank you!
http://energysea.net/forum.php?mod=viewthread&tid=8447&page=2&extra=#pid48874
Please tell me if there is a problem. Thank you!
ramset
Sir
The good news is we have very skilled persons here who can verify this claim quite easily
However
I must ask
is this an actual result you have seen after building this ?
or is this something you "expect" should happen based on you calculations and method ?
The language barrier is a problem,however we do have friends here who can help with that.
But Clarity is important
Have YOU done Empirical testing or is this theory ?
respectfully
Chet K
Thanks Grandma
panyuming
Quote from: ramset on May 04, 2018, 05:41:10 AM
Sir
However
I must ask
respectfully
Chet K
Hello Chet K!
As you said,
" you "expect" should happen based on you calculations and method ?"
Sorry, that's it. It's just my calculation.
