0 Members and 65 Guests are viewing this topic.
stivep
My posts will not be frequent. Wesley
stivep
1. this schematic of the pump is not mine  and it  applies to electrical equivalent  of water  pump but this is  absolutely  the concept of  electrostatic pump. ( search Free Energy Well Pump to find it  - it is on web side not on video )
2.  kapanadze coil capacitor https://www.youtube.com/watch?v=0Z3S4R_wycU
3. kapanadze coil capacitor  https://youtu.be/0Z3S4R_wycU?t=597
Please note that frequency of spark gap is very low ~ 20Hz
4. Kapanadze Tent presentation - bank of  capacitors serving as part of coil capacitor  circuitry If you interested than please find model number and internal structure of it
Wesley
stivep
This is copy of  translation done by:AlienGrey from Russian into English
Quote from: AlienGrey on May 25, 2018, 01:56:22 PM
  Logged
stative
Hero Member
Re: Kapanadze Cousin - DALLY FREE ENERGY
« Reply #19885 on: Today at 04:26:04 PM »
Arunas may the ask You for help with the Translation as with the a well:
the Conversation of by Wesley with the Cheshire Cat https://www.youtube.com/watch?v=_9foRzZEZRo&t=613s
Please note Note That larger part of such conversation is not related to the this are subject
and there are few separate conversations.
find the right one.
Wesley says:
Easy answer: the
density of the electron beam in the conductor: electrons of different types of atoms have different degrees of freedom to move.
With some types of materials, such as metals, the outermost electrons in atoms are so loosely related,
that they randomly move in the space between atoms the effect of temperature changes in the room so that there is no need for an electric current in the conductor.
Since these practically unconnected electrons are free to leave their respective atoms and float
around in the space between neighboring atoms, they are often called free electrons.
In other types of materials, such as glass, the electrons of atoms have very little freedom of movement.
- the insulating material (foil) acts as a medium for increasing the electron density)
If we want the electrons to flow in a certain direction in a certain place,
we must provide the correct way for them to move, just like a plumber must
install a pipeline so that water flows where he or she wants it to flow.
electrons can move freely in the conductor.
They have a drift speed of 1 cm / s, but when we see a conductor (for example, an antenna), the electron
does not actually move along the entire length of the conductor, it just vibrates around its middle position, and its energy comes forward.
============================================ The
actual drift velocity is highly dependent from the geometry of the conductor, the magnitude of the current flowing
and the density of the mobile charge carriers (the drift velocity is proportional to the current and inversely proportional to
the cross-sectional area and the mobile carrier density). 50 Hz, in Russia,
electrons do not drift very far.
A large number of electrons collectively shift their positions .... a little, but the current but can be very high
Signals:
propagate along the wires at very high speeds.
If the lead is excellent, the signal propagation speed depends on the insulating material around the wire.
This is due to the fact that the energy transfer is actually in the electric and magnetic fields.
The Poynting vector is E transverse B and is proportional to the energy flux per unit area per unit time,
and since the electric field vanishes inside the conductor, no energy flows inside the conductor (!),
Only from the outside, in close proximity.
The propagation velocity of the signals then depends on the dielectric properties of the insulation, and usually
about 70% of the speed of light.
The electrons only flow in the conductor to satisfy the conditions of the electric and magnetic fields
obeying the Maxwell equations on the conductor surface.
About alternating current - the average AC value of the current in the circuit must be zero
(if there is no DC offset), the current flows back and forth continuously,
The opposition to the current flow through the AC Condenser is called the Capacitive Reactance
which itself is inversely proportional to the 'supply' frequency of the supply
This factor is directly responsible for storing the energy and density of electrons in the conductor.
so the larger the diameter of the conductor, the higher its ability to temporarily store energy
. So this is not really a diameter that is important, but the surface size of that conductor.
It can be porous or deformed.
================================================== ===== The
collection of the time charge can be made at any frequency (for example, the frequencies of the arrester spectrum,),
but the energy is fed further on at the resonant frequency of the equivalent of the LC circuit of this coil.
The best signals for this are narrow but short rectangular HV pulses. One of the best known methods
consists of two generators. ABOUT
One generator produces a sinusoidal signal at a frequency of 5-20 kHz, and the second oscillator modulates the sinusoid modulation
with a narrow high level of the deviative position-
or better say the positions on this sinusoidal signal (the best position is 5 degrees
after the maximum position of the positive sine wave)
Kapanadze's reel in the aquarium # 1 was made of a wide copper foil to increase its surface.
If you want to have a shorter coil length,
However, two copper foils, insulated with foil, greatly enhance the capacitive resistance of these two or
three or any number of them - the copper foil must be connected very accurately.
If you connect the last two ends of this foil together, you removed / removed the reactive impedance components to zero.
You do not want this to happen. (Bifilar form of communication).
Therefore, all the front ends must be connected together and have a foil in between.
But only one end should be used from the opposite end
to better understand this: - Take 10 thin copper strips of copper foil 5 cm wide - take 10 thin strips of foil 5 cm wide
If you use high voltage for pulses than the insulating film should be wider 5cm + 1cm ~ / = 6cm
- stack them one on top of the other.
-You can roll them up like a capacitor
- Front end (all insulated between copper strips) are soldered together.
- the other part (10 strips of copper foil), only one end of the length of use of the sandwich can be, for example, 10 m
but when it is rolled into Cylinders, it occupies little space
resonance frequency of such a condenser coil depends on its capacitance and inductive reactance.
Quick the Translation:
to the get a better Understanding of the this - take 10 thin copper foil strips 5 cm wide
the If you use high voltage for Pulses than the insulating film Should the BE Wider 5cm + 1cm ~ / 6cm
-You can roll them up as a condenser
- the front end (all insulated between copper strips) is soldered together but only from one side. That increases  surface of such structure adding to it capacitive reactance.
On the other end  of (10 strips of copper foil), you  only use one end  out of 10.
ther rest 9 ends must be not connected.
to better use the length of such a sandwich  you can:
roll in  all  of them into a  form of cylindrical structure.
Such structure   occupies  small space.
The frequency of resonance of such a coil capacitor depends on its capacitive and inductive reactances.
Spark gap  bandwidth is from single Hz to 1GHz   with one  but significant  High amplitude region.
Collecting energy by such coil capacitor  is taking advantage  of all of that  spark gap spectrum components.
But  output of coil capacitor (  the far end  of  just  one  of  the 10 single copper strips)  does it  at resonance frequency of such coil capacitor.
IF you have noticed  Tariel in TENT SHOW used humongous coils  ( not  Grenade) but strange it was to see big bank of AC capacitors next to it) !!!!
I assume but I'm not sure that these capacitors have been slightly modified to to form  described by me here.
If not  than please take model number  from  TENT PRESENTATION  of such capacitors and you maybe able to find drawings of its internal structure
At the right frequency of stimulating impulses, you will be able to get the trigger of coil # 11 (or otherwise coil that is connected to the ground with diode)
look below for instructions.
Note:
by that we may also understand that use of capacitors.
How to make electrostatic pump:
          You can also add another copper foil number 11 along with the other 10 (copper foil).
This copper foil is not connected at all to another.
Now connect this copper foil to the ground wire using a diode between the ground and the foil.
Polarization of the diode must be in its conducting direction from the ground to the copper foil.
You have now made an electrostatic pump.
И это - 90 % успеха вашего СE.  (закрутите винтoм орехи  царя)
Quick Translation :
You can also add another copper foil number 11 along with the other 10 copper foils.
This copper foil is not connected at all to  set of others 10 foils.
but this strip is winded along with  other 10  copper foil strips insulated in between .
Again please understand that  even if these 10 strips are connected  together from one side ,their surface   is 10 times bigger than  single copper strip.
that  work at significantly lower frequencies .
this concept is taken from Tariel Kapanadze  aquarium #1 ( the red coil cpacitor with shiny something in the middle).
You can see from the picture that he soldered all of copper  strips in the middle
and than winded all together.
Than only one from strips was used from outside
I hope you can understand it .
And now connect this copper foil #11 with the ground wire using a diode in between
( using a diode between the ground and the foil #11.)
And this is 90% success of your FE. ((tighten the screw around the Russian  king's nuts))
It is to much to translate. Try to use  translator  I  hope it will come somehow    logical.
This is due to me being allowed now to go that far  with sharing of information that is in my possession.
-Please  understand that number of strips is not critical.
- It is  just one of solutions of Tariel.
- electrostatic pump is my  own  way to explain  processes
Tariel was able to intuitively   by errors and trials to understand how it works.
Tariel is not  so advanced to be able to  explain why it is  happening. He only knows how  to make it.
Later modifications especially by SR193 have been using slightly  different approach.
Grenade coil  serves partially  similar function using canceling  of reactances in 3D geometrical space of  adjacent coils
It is not only one way to get results .
That is why  I concentrated myself on understanding phenomena .
Honestly ....
Wesley
PS;
4. Kapanadze Tent presentation - bank of  capacitors serving as part of coil capacitor  circuitry  Please find model number and internal structure of it
I did my part you do yours
d3x0r
Hi :)
I know this is a little out of your wheelhouse - so to speak... but was wondering what you thought of this idea...
(PDF attached of patent, next message has links to patents on web)
https://overunity.com/17653/pierres-170w-in-1600w-out-looped-very-impressive-build-continued-moderated/msg521687/#msg521687
Unfortunately the original videos are no longer available.... The difference between patent and Pierre's device is DZ Generator uses manual switching instead of external phases...
Hoppy
Hi Wesley,
Its good to see that you have started your own thread.
You wrote: -
"But interesting point I could make here:
not always all of the factors are immediately visible.
My friend is science Dr. Roy likes to say.
"Only the magician knows his tricks."
that does not mean that automatically all tricks are not scientifically valid."
A wise guy your Dr. Roy!
I hope you won't take this the wrong way but you do come across as being strongly biassed towards the opinion that Kapanadze's devices are genuine self-runners. I find this rather strange that given you clearly have good technical training and education and yet, although you have seen some of Kapanadze's first hand, you have never had the opportunity to conduct a proper physical instrument based technical analysis on any of them.
I'll leave you with these shots from Kapanadze's / Akula's videos that I feel uneasy with: -
