0 Members and 85 Guests are viewing this topic.
Void
Hi Wesley. LEDs/LED bulbs will light any time they have a suitable amount of
potential difference across their terminals (anode/cathode) which can supply the
relatively small amount of current they need to light up.  When you place the end of a LED bulb
on an at least a somewhat conductive surface which is in a strong HV electric field,
and touch the other terminal of the LED bulb with your finger, your body is acting as a
virtual ground at a much lower voltage potential to complete the circuit. Without knowing the
input power to the voltage source(s) you were using to create the HV electric field, I think it is not really
possible for anyone to judge whether there was anything out of the ordinary going on there
in your demonstration or not.
I tested with this a little today with just a flyback transformer driver at about 4.5W input power to the
flyback driver and it could light a small led bulb, although not very bright, when I put the end of the
LED bulb into a small bowl of commercial filtered water (DC resistance measured 8 to 11 megaOhms),
and touched the other terminal with my fingers. The bowl was placed close to a capacitive 'top load'
connected to the HV terminal of the flyback driver. The LED bulb I was using didn't light very brightly at that
low 4.5W input power level however. That might be due to the circuitry that is in the bulb reducing the
current flow to the LED bulb with the low input power level to the flyback driver not being enough to overcome that.
What total power input were you using when you lit the LED bulb? So, you think that the phase shift when
using the 'charge line' makes a big difference in performance? Were you monitoring the input power difference on
your high voltage source(s) comparing when the LED bulb was not lit compared to when it was lit?
Quote from: Ansis on January 12, 2019, 04:10:08 AM
Idea is Tone Fork 440Hz.
We make kick and Fork start to resonate.
More kicks, lauder sound.
Thicker Inductor, more Amplification.
Fork=50Hz resonator, Kick=Spark.
https://books.google.pt/books?id=FzbBK6m8qxEC&pg=PA98&lpg=PA98&dq=parametric+generator+papalexi&source=bl&ots=DAhHCWmxUk&sig=5vw-mY_uWBFGvdXUXmvC5WdmOMM&hl=de&sa=X&ved=0ahUKEwjD8anI3uzfAhWNgM4BHdnXC7UQ6AEIETAD#v=onepage&q=parametric%20generator%20papalexi&f=false
videre : Video.                     audire : Audio                    signare( written, spoken ?) : Signal (~  physics: pulse )
https://en.m.wikipedia.org/wiki/Undertone_series
https://en.m.wikipedia.org/wiki/Subharmonic_function
https://pages.mtu.edu/~suits/overtone.html
La-la-la-la-la-la-la : tone scale  ? harp strings, claviatur strings /     "synthetic strings" :  syntheziser/ keyboard
eV, nm !  : dB ?
  Sub-harmonic resonance to super-harmonic resonance. : total resonance bandgap and bandwidth
                           Color : Klangfarbe "Dreiklangdimension".  https://de.m.wikipedia.org/wiki/Klangfarbe
                                              VIDEO-/AUDIO-SIGNAL : TEMPERAMENT/TIMBRE
                                            https://m.youtube.com/watch?v=N9dsjcTzHoM
                                              " ..... Lichtspielimpressionen, so farbvoll ...... "
                           A-/ Symetrie.   ( or Dis-) Symetrie
                           A-/ Synchron.  ( or Dis-) Synchron
                           A-/ Harmonic  ( or Dis-) Harmonic
       Is an Orchestra in its dynamics " dictatur"  or " democracy"
       The Dirigent : Dictator or Demokrat ?
       How to become the right democratic Dirigent from the "E.M.L.O",
       Electro-Magnetic Light Orchestra, Light-Cinema
AlienGrey
Look I'm no professor on this (cabbage) whatever that is ;D but yonks back Akula started some experiment with a 555 and a cd4017 and a pile of diodes
and a 4 phase toroidal winding, does anyone remember that one The commentator talks about connecting with the earth's magnetic Force while trying to push it along the table (here we go round the mulberry bush)  ;D Akula started showing it and then 'bang' gone, nothing!
now Wesley is into 90 deg phase shift.
Also, does anyone know what a photon generator is it takes in seawater produces ENERGY many times OU and then chucks the sea water back out or round again (re Revers the Grid campaign? published by free energy party on Facebook look up Dave Parker if interested not me.
Also there is this https://www.youtube.com/watch?v=70_xKJh91eE   READ his notes !!!!!
stivep
Quote from: Void on January 13, 2019, 11:17:57 PM
I  did not touch  any other terminal of the lightbulb as you see on the pictures
Wesley
stivep
Quote from: Hoppy on January 14, 2019, 04:35:26 AM
  :( C'mon Wesley, stop playing tricks and put all your cards on the table.
At first it is possible. Needs to be little warmer. And I really do not want to show this lab from outside.
As I said, I created surface wave on  the interface.
Interface is the space between two different lossy mediums ,
where  one of it  is dielectric and the other is air.
And because I was still in in Near Field that is why I had sparks in my mouth.
I have had  no horizontal space to be outside and  do the same. Too cold.
However at  parking lot approx 1120m (1.120km) away . I was still getting  strong reading.
No I did not try light bulb there. I have XYZ  isotropic field meter with XYZ  probe connected by fieberoptics  so it  eliminates  any parasitic influence on the probe  and processing unit.
that was  reading  not  XYZ space.
But earth air interface.. with some  form of resonant transformer just placed  on the surface of it.
Wesley
