0 Members and 52 Guests are viewing this topic.
Void
Quote from: stivep on January 14, 2019, 11:04:38 PM
Dear Void. Corona  seen on conductor in Tesla coil has nothing to do with dielectric.
There was no single piece of wire or any conductor.
Hi Wesley, I was talking about the corona discharge (low level arcing which is clearly visible between the
two blocks of TIVAR in the picture which I highlighted above. This corona discharge is occurring
because you are holding on to one of the TIVAR blocks which is effectively grounding it, and since
the TIVAR blocks are clearly conductive at high voltages due to the carbon content in them, the other TIVAR
block charged to a high voltage due to the very strong electric field it is in is creating corona discharge (low level arcing)
in the small air gap between the two TIVAR blocks. FYI, 'sparking' is a type of short term corona discharge. :) Arcing is where
the air completely breaks down due to a high voltage and you have a considerable current (relatively speaking)
passing from a higher voltage potential to a lower voltage potential through the air or other medium.
All the best...
Quote from: Void on January 15, 2019, 03:21:28 AM
All the best...
Wow, I thought several hours before , not that I do not know this papers,  but reading it more concentrated :
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=Ken+hayashibara&IN=Kazumi+masaki&CPC=&IC=
f.e.:
https://worldwide.espacenet.com/publicationDetails/description?CC=US&NR=4701675A&KC=A&FT=D&ND=3&date=19871020&DB=EPODOC&locale=en_EP#
60 W : (130 V x 200 A) arc discharge current ( which makes part of the inrush current kind )
60 Wnominal average : 26000 VA peak
Voltage divider,Frequency divider : Pulse divider
impulse spark gap : Space-Time calculation f.e. electrophorese like EDM or arc welding or Plasma welding
Maths world "Raum-Zeit/Space-Time" : https://de.m.wikipedia.org/wiki/Kartesisches_Koordinatensystem
          applied f.e. 4d- nano-chirurgy by C.N.C. and in future EPROM based
Void
Quote from: Hoppy on January 15, 2019, 04:49:36 AM
Excellent video Void and the music! 8)
Maybe this will help rid this thread of this LED bulb lighting nonsense and get back to ways to light Kapanadze style 1KW bulbs with free energy.  ;D
Hi Hoppy. Thanks for watching mate. You would think that such an experiment will help to dispel some myths,
but that is not typically how things go around here unfortunately.  ;D We will see what Wesley has to say
about this experiment and the conclusions I draw from it. :)
stivep
Thank you for your video and your time.
anything what you say  at any frequency would be noted in literature as  this material is used in American government test facilities.
In  Product Data Sheet on the top you see material listed:
Quadrant EPP TIVARĀ® DrySlide UHMW-PE, Lubricant Filled, Electro Static Dissipative
UHMW-PE
I explained in  https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg530113/#msg530113
and in
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg530118/#msg530118
Material used in experiment had nothing to do with charcoal or any conductive  material under any circumstances.
so again Void :
It is  the type of insulator that never becomes conductive
All of you can not accept that this is  how  surface wave manifests itself on dielectric.
Visual presentation  of how Kapanadze device works in the field may give to some of you some answers .
There is  former airport about 40 minutes from me.
It could be any flat open field I could find. But it is to cold outside.
I'm going to make few tests.
the bottom line is:
The same Zenneck surface wave used by Viziv   is used  by Tariel Kapanadze to extract energy from Shumann waveguide.
Energy fluctuation inside the waveguide are affecting its boundary.
Shumann waveguide  boundary  Earth  serves as interface.
And method of extraction of this energy  was the dilemma that one may patent to no longer deal with disbelieve of crowd.
If it does not work for you it works for other guy
what's a problem?
Wesley
