0 Members and 31 Guests are viewing this topic.
Void
Quote from: NickZ on January 15, 2019, 12:23:48 PM
   Guys: The Schumann resonance frequency is now frequently changing, and has had bursts of up to 90hz.
Which means that if a device is tuned to an older Schumann frequency, it may not work the same now.
What if this mentioned frequency has nothing to do with what Tesla was mentioning about tapping into the ambient surrounding energy. The Cosmic soup, etz...
What if you leave the planet? What frequency does deep space hold?
   May we be barking up the wrong tree? Maybe it's not the Schumann resonant frequency at all, that we should be tuning into.
Hi Nick. I have not so far seen anything at all that gives any compelling indication that Kapanadze
may be making use of Schumann resonance waves at the surface of the Earth or similar. Kapanadze
himself may not know at all where the energy is coming from.  He may just know what to do to
make a working device based on some info someone passed on to him at some point, or possibly from
some obscure document he came across, and possibly just not know where the extra energy is coming from.
(Assuming it really works as claimed and as demonstrated by Kapanadze).
Sergh
Quote from: blueplanet on January 15, 2019, 09:20:50 AM
This is another piece of disinformation because of the minority opinion.
Previously, another vocal individual has voiced the same concern. I was trying to comment but I finally gave up. Every real antenna engineer knows what's wrong with your concerns #1 and #3.
Can you read these articles from independent engineers?
http://www.vlf.it/kurt/elf.html
http://www.longrangelocators.com/forums/showthread.php?t=18969
https://jwcn-eurasipjournals.springeropen.com/articles/10.1186/s13638-018-1157-7
If you are a electronics engineer, you need to understand how low the level of energy is.
stivep
Schumann waveguide should not be seen as Schumann resonances per say .
Schumann  Resonance only allows you to send  signal from point A to point B without significant losses.
That includes Ground Wave, Surface Wave, and traditional  electromagnetic  communication.
The guided wave travels along  curvature of the earth.
And that is  about all in this area.
Corum Bross included that information in their patents.
The novelty  is  extraction energy  from that Schumann Waveguide.
So  in the big picture there are two alternatives:
1- Tariel  knows about Surface Wave but he  had no idea  that he deals with Surface Wave.
Theoretically to make Tx and Rx for such assembly  is about 1 to 3 days.
And for these who did it before  1 to 3 hours.( with help of two, three people in physical assembly)
1a- testing and tuning takes  few hours to few days but less than 3 days for starters.
1b-
There is indication that in the island presentation light in the motel  dimmed significantly.
Tariel was across  the water on the island. Part of his crew was in the motel.
That fact was  absolutely proven by my very credible  sources.
However we may say that it was purely coincidental.
2- Tariel knowing technique of Zenneck  transmission went further  up and extracted energy from Schumann  Waveguide
That is in theory even simpler than transmission of Zenneck Wave  as you do not need transmitter.
Each lightning strike  creates avalanche of  lightning strikes around the earth.
QuoteHigh quality lightning data has only recently become available, but the data indicates that lightning occurs on average 44 times every second over the entire Earth, making a total of about 1.4 billion flashes per year.
All  of them must dissipate in the earth.
Wesley
Quote from: Void on January 15, 2019, 03:02:45 PM
Hi Wesley, thanks for the comments.
As I see it, the problem is IMO that you have not said or demonstrated anything so far that
would seem to lend concrete support to the idea that low frequency waveforms at the Earth's surface
are being tapped into as the source of the extra energy. I am not saying that idea is necessarily
wrong, just that I don't think you have presented anything which seems to give real support to this idea
of yours. Why do I say 'low frequency' above? Because Schumann resonance frequencies are supposed to
be quite low frequency.
It will always come back to the same point with anyone anywhere (not just here) in regards to these type of ideas.
If a person can't show anything concrete to back up the notion that energy is being extracted from the Earth's surface,
then people can only take it as an as yet unsupported idea. That's my point of view anyway.
Related Schumann frequency spectrum :
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fwww.planetware.de%2Ftune_in%2Fschumann.html
