Void
Hi Wesley. You seem to be taking people's natural hesitance against jumping to conclusions
about these sorts of things personally, but it is not personal at all. For myself, not wanting to jump
to any conclusions about this sort of stuff comes from long experience.
I am actually not ruling out what you have been saying at all in regards to Earth surface/ground waves
of low frequency as being the possible source of extra energy in these setups. I am thinking about
it and trying to see how it might work. The fact that Frank Wyatt Prentice seems to possibly have done
something similar to that approach in 1923, makes me think it may be possible.  See the attached
Prentice drawing again.
The top 'Transmitter' section has a long 800m approx. wire a short distance above the ground
and a sparkgap at the end near the end grounding point. The sparkgap may cause disruptions/disturbances
in the ground underneath which may draw in energy into the long wire from low frequency waves in the Earth
and thus increase the energy on the long wire by a factor of about 6 when it was all tuned properly.
The small receiving loop is tuned to the transmitter frequency and receives this 'amplified energy' from
the long transmitting wire. If we replace Prentice's 800m long wire with a short tuned coil, it might
still work about the same. It does seem to possibly mirror Kapanadze's setup fairly closely, except
Kapanadze used a much more compact transmitter/disrupter and receiver coil assembly. Am I close
to your ideas Wesley? :)
P.S.
Maybe what Kapanadze had in his tobacco can besides a flyback transformer was a tuneable HV capacitor (#23 in Prentice's drawing)...
Void
AlienGrey
Wesley Hi this is my contribution a four-phase clock contribution.
If you want a 50 Hz or 60 you have to drive it with 4 times that frequency
The CD4046 is simply a stable VFO
https://overunity.com/6763/energy-amplification/3555/
#3556 and #3564
     Tekla Ozkan " simple thinking" ( ~ Tanaka Saburo,  Keiichiro Asaoka Inverter generator)
http://www.patentsencyclopedia.com/app/20090079393
Attention,  probably " getuerkt" !  ::) ;) ;D
For " more complexity thinker" :
Triangle 1 : DC/AC left-/ or up helix
Triangle 2: AC/DC right/ or down helix
Tornado ? N-P-N holes principle ?
N1 : CCW or CW
P
N2 : CW or CCW
   NPN Trans-Resistor " Transistor" ,      a.  Photo-copler  b.  Phono-copler          to RTS/HTS
BTW : https://www.ebay.co.uk/itm/1932-Bridgeport-Phono-Electric-Trolley-Bus-Ad-wg393-MBFA2Q-/290875565380?redirect=mobile
alloy material mix ?
Ansis
To Void, Wesley.
I see you are back on the right track!
Void, I think like you about 15 years from now.
Your Wireless Video was realy good!
Wesley, I think Kapanadze use sea water like medium, but very thick multi strands wire which he buried in the Sea was Antena. It is Energy from Medium, which contains EM Field. He makes loop.
In that loop he amplifiere field.
Thats it!
