Quote from: F6FLT on January 17, 2019, 04:47:33 AM
I had seen this article when it came out, source paper here. It would be revolutionary in principle, since it would be a Maxwell demon.
On the practical side, the energy in question is on the order of tens of pW, so no practical interest without considerable improvements.
But there are worse things. This scientific paper is questionable.  Cooling was not measured but calculated. The paper was refuted, a real measure would have indicated an absence of cooling:
http://large.stanford.edu/courses/2012/ph250/kumar2/
"The authors did not directly observe cooling, mostly because they did not thermally isolate the diode, instead they chose to keep the temperature fixed! They calculate the net cooling. In simple terms, one would not observe cooling in the recombination dominated region."
In the recombination dominated region I expect : 0 change in Kelvin !
Sergh
Quote from: lancaIV on January 17, 2019, 04:51:09 AM
       "C. THE RATIO FROM POWER FACTOR AND HEAT FACTOR APPLIED "( + Newton* meter Factor)
                  " picowatts "- device as q.e.d. for him and his POWER KW/KVA RATIO description :
               to  mega.
http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=DE&ENGINE=google&FORMAT=docdb&KIND=A1&LOCALE=en_EP&NUMBER=2733719&OPS=ops.epo.org/3.2&SRCLANG=de&TRGLANG=en
https://www.unitjuggler.com/convert-power-from-pW-to-W.html :'(
Ansis
Small update.
To everyone.
Do you have Made in China Joule Thief type  HiVoltage transformer, Tesla style?
https://thumbs2.ebaystatic.com/d/l225/m/mjrpl-NbzG9qfntqZiM2lcw.jpg
Do you have "metal water pipe"?
All magic is in "pipe" and in the HiVoltge source.
When you playing with Sparks, Ozzone :), nothing extraordinary.
But when you attach "water pipe" through wire to the violet terminal of the mini Tesla style transformer, be very very carefull, because "mixture" of Currents can kill you!
I get internal burning of my finger with "cooked flesh" smell and black dot.
This is that.
When you have these 2 parts together and if you make loop, than we can get "energy".
Kapanadze love that word.
Энэргия пошла!
Quote from: Sergh on January 17, 2019, 06:25:18 AM
https://www.wired.co.uk/article/230-percent-efficient-leds
VA~ W ( several power definitions!) VAh ~ Wh
LED:                          Unit VOLT x Unit AMPERE ~ Unit Lux as power indicator
                                  1/2 from above Unit VOLT x ? Units Ampere ~ Units Lux
                                  as reduced a . Light b. electric power factor
                                   FACTOR OF FOUR : FACTOR OF TWO
Mukherjee device:
DC-motor( and generator) in one + Controle-Unit
Technical process to counterbalance F( orce) :
        balance,wagging,
        left side leg and right side leg
Left side leg :
Paragraph : " If in a conventional generator the field strengh B.......  F= B LI
Right side leg :
Paragraph : " If the field strength of the electrical device -edit: is- 2B...... F'=2Bx L x I
F/F': B/2B : 1/2 Ampere current x 1/2 nominal Voltage = 1/4 nominal VoltxAmpere
Edit : f.e. B/10B : 1/10 Ampere current x 1/10 nominal Voltage = 1/100 nominal Volt x Ampere
              ( Counter-) BALANCE OF POWER
Pico-Watt ...... Watt, KiloWatt, MegaWatt
::) IS this the End?  NO,  coil length = the I from BxLxI variation and
the " pure output energy force" can be also extracted from the shaft : kinetic force/ energy as power source
There are many FE devices,  based by physics formula applying and logical maths. ! Conventional EE-regime and Quantum-regime!
To have a pure 80% -<100% pure electromagnetic converter is a very good beginning  !
1Watt-hour source : seems not much
1 hour = 60 min. = 3600 sec.
Let 1 Wh cycling 3600 times/h= 3600 Wh
Hertz: " motionfree" rotation/ cycling
Hz,KiloHz,MegaHerz,GigaHz,TeraHz,....
1 Wh x THz- times : ? Wh
80% to < 100% EMF efficiency
+ elektret EF and/ or  permanent rmagnet MMF
Efficiency amplifier : > 100%
