0 Members and 84 Guests are viewing this topic.
AlienGrey
Quote from: r2fpl on January 18, 2019, 07:50:09 AM
These are not Schumann's resonance waves in Kapanadze's devices.
I think you will find all the KT device ones that work are base 8 or 9 or a combination and even the Don Smith device was 31k5 (3+1+5=9)!
Or you could do it the dummy's way 31,500khz / 9  goes 3500 times! which is the Univers! or the God number
Void
Quote from: Hoppy on January 18, 2019, 04:01:18 AM
Void,
I'm wondering if it intended to replace the wired grid but not the power generating hubs? I cannot see this idea being viable unless all infrastrucure costs, including de-commissioning and removal of the existing grid networks are bourne by the tax paying public, so therefore, only escalating energy costs to look forward to. Also, the system will need to be able to pinpoint all leakage and illegal tap points to stop guys like you from getting a free   meal  ;) There are likely to be H&S issues that although unlikely to raise real problems to its implementation in the US, may well in Europe under its present political structure. So, likely just a rich guys toy at present.
Hi Hoppy. Yes, I would guess that is the plan. Maintaining the wired power grid is
very costly, so if power corporations could do away with all that cost by sending power
to most places via the ground, they could greatly increase profits, and that is what
corporations are all about. Maximizing profits. Yes, at this point it just appears to be
an expensive experiment, so that is why I was curious who all is funding this project.
It will be interesting to see what they can do with their variation of a Tesla magnifying transmitter
tower under a new name.  :)
r2fpl
Quote from: Hoppy on January 19, 2019, 04:22:49 AM
Most likely not. We do not see him make any fine tuning adjustments and the length of ground cable appears not to be critical, as he swops over from the radiator ground wire to the water pipe ground and these are very different lengths of wire. The electrical conductivity of the ground is probably more important, as the device appears to work better on the water pipe ground. I think Ansis is closer to the truth, that the device is using the water pipe with its 'hard' connection to grid earth as part source of the energy supplied to the device. I think the discussion would be more productive if ideas on how indirect grid connected powering might be achieved, that is without a straight and faked direct connection to Tariel's house mains consumer unit, at least to eliminate this possibility, rather than continue with the more complex and esoteric idea of powering with surface waves.
There are rather two possibilities:
1.The system works by supplying it with energy through air and ground. Just like the Tesla wireless system.
2.On the principle of accelerating electrons by an HV resonator.
#1 - the success of such a system is 100% and this is a scam.
#2 - such systems have low efficiency but all work 100Mhz to nGhz
What would happen if they were forced to operate on frequencies of 10Mhz and less?
