Ansis
Hi!
There is only 1 biggg problem with Kapanadze "coil"(That is not Tesla Coil).
We need Sinuss+Spark.
Every transformer with 50-400Hz range, have metal cores.
Ferrite is used at much higher frequencys.
In original? Kapanadze drawing we see Ferrite+Bifilar type of core-coil.
In fact, my friend tell me, look at Kapanadzes desktop!
There was black material and hammer.
Skype commrades remember what I write about very low technology of Kapanadze.
We see primitive laboratory.
No HiEnd.
Core is veryvery important part of All "FreeEnergy" generators.
TPU or Kapanadze use the same principle.
MagneticField multiplication with Mechanic type of resonators!!!
I think, we must copy Kapanadzes coil.
And yes.
Inductor 6 turns is connected in series with 6+6 fat wires(Litz or simple?).
It is important to feel all lenth of coil with Magnetic Pulse+Sinuss!
It is for Maximum efficiency.
Maybe Spark must be tuned to Maximum and Minimum of 50Hz "modulation".
To make copy of that coil we need 1?- 3? days?
We need 2 generators.
I have only oscilloscope and no generators.
I use PC. :)
r2fpl
The system must be open or grounded. This is the basis for further action.
The principle is the same only describes it differently.
http://www.nutsvolts.com/magazine/article/the_magnetic_amplifier
The " magnetic amplifier" for itself is a system control device !  Which makes part for a semi-loop FE-device !
Loop-/ closed systems= storage
generating maschines: open input/output circuit  !
Hoppy
Quote from: jojo500 on January 19, 2019, 06:20:58 AM
if you look how slopy his kontraptions are made i would say if anything than a few khz .. but never MHZ ore above.
how ever i said this long bevore. Look at all the work they put in to the groundingpoint  and than look what cable the use
one woult think  if you want to have a perfekt ground you keep the distance close to your device and  use som substandcial wire for that.. but they don't so what does this wire?
Agreed, in electrical best practice sense but I think Tariel chose his demonstration area as higher importance over the location of the grounding point. So, the ground is important to the optimum efficient functioning of the device but its length is not critical in my opinion. We observed no evidence that the device could operate without the ground wire, despite Tariel's comment to the contrary. However, we did observe that the quality of the earth connection had a marked effect on the brightness of the lamp load. Also, the heavy gauge of the ground wire and clamp meter readings, suggests that it may have been carrying a heavy current but not necessarily at a full grid voltage level. How could Tariel have powered his device from a cleverly 'processed' high differential ground voltage, so as not to have registered on his consumer electricity meter and without making any wire connections within his service compartment / box / cupboard? Remember, at the time Tariel carried out his box demos, grid power 'tapping' was well practised and widespread in Georgia. We need to totally eliminate the liklihood of this before seriously considering the alternative more technically complex possibilities already put forward.
AlienGrey
if you look how sloppy his contraptions are made I would say if anything than a few kHz .. but never MHZ ore above.
however, I said this long before. Look at all the work they put into the grounding point and then look what cable the use one would think if you want to have a perfect ground you keep the distance close to your device and use some substantial wire for that.. but they don't so what does this wire?
I don't think so! You really need to read more
