0 Members and 23 Guests are viewing this topic.
Void
Quote from: seychelles on January 19, 2019, 11:36:19 PM
@ VOID, to prove that an air conditioner is an over unity machine is easy.. It can more
efficiently cool your room and heat up water simultaneously than just cooling your room..
That has to be proven, but from my little experience that is over unity..Not by this observation,
but by calculating the electrical power consume as per the work done.
Hi seychelles. It is not over unity. For example the electric circuitry and electric components in a heat
pump are not producing more energy than they are consuming (which would be over unity), the heat
pump is pumping heat from one place to another. If the total energy in the heat that is pumped
is greater than the input electrical energy being expended by the heat pump circuitry, then
that would be a COP > 1. Look up coefficient of performance (COP) if you want to learn more about it.
All the best...
seychelles
What i am saying is that if a person calculate the time it take to cool a
1liter condenser, of water and heat up a different 1 liter  evaporator of
water simultaneously one will come to the conclusion that the electrical power consume
in this process compare to work done  is cop >1..
Ansis
About heatpumps.
There is 1 Country which have Heatpumps with COP>10000 or more :)
It is Iceland.
Because they have Vulcanic heat for Free! :)
In Latvia where is cold in Winter, we are not so happy.
Peoples who make very deep drills in to the ground, get better results, but if they make cheep
setup, then COP≤1. I know many real stories...
Quote from: Ansis on January 20, 2019, 02:34:36 AM
About heatpumps.
It is Iceland.
Searchmachine : Super Deep Fusion Drilling
Each place on earth can have this " Vulcano-deep whole"- dis-/advantage and explore potential
Quote from: seychelles on January 20, 2019, 01:02:59 AM
https://www.google.com/search?q=hot+cold+thermal+generator&client=firefox-b&oq=hot+cold+thermal+generator&gs_l=mobile-heirloom-serp.3...21730.26639.0.27274.9.9.0.0.0.0.225.1382.1j7j1.9.0....0...1c..34.mobile-heirloom-serp..2.7.1058.SjivexS_WCA
A very cold side for free ( Ant-/Arctic )or a very hot side for free ( Solar concentrating Tower ) ?
Or a cold/colder/coldest cascade ( - 180° C ) Schukey Delta Omega Machine :
https://www.google.com/search?q=schukey+delta+omega&ie=utf-8&oe=utf-8&client=firefox-b
Probably also by analyzing : "Diode" ! Material,  configuration, function in a conductor, effect
and micronizing such idea :
  https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=28&ND=3&adjacent=true&locale=en_EP&FT=D&date=19920507&CC=DE&NR=4035445A1&KC=A1#
for example for up to 2000x solar field concentrator cells as cooling device or Plasma charge controler
Easier : an " endless belt,  bimetalic" , hot bassin and cold bassin and belt moving from hot to cold to.....
Endless belt motor :
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=Endless+belt+motor&AB=&PN=&AP=&PR=&PD=&PA=&IN=&CPC=&IC=
Endless belt generator :
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=Endless+belt+generator&AB=&PN=&AP=&PR=&PD=&PA=&IN=&CPC=&IC=
Endless belt converter :
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=Endless+belt+converter&AB=&PN=&AP=&PR=&PD=&PA=&IN=&CPC=&IC=
