0 Members and 74 Guests are viewing this topic.
Hoppy
Quote from: Void on January 19, 2019, 04:16:19 PM
Hi Hoppy. Thanks. Yes, I am well aware of all those things. However, I have probably run about
40 or 50 test runs with close variations of this particular arrangement alone in the last couple of months,
so I know well what is normal discharge rates for my specific setup and what is out of the ordinary.
The latest results do appear to be somewhat out of the ordinary compared to all the other test runs. However, I certainly
could still be overlooking something which is contributing to the seeming out of the ordinary results I am seeing,
and I am still looking into it to see if I could be overlooking something. No one said this type of experimenting is easy. :)
It really takes a lot of careful analysis and testing to try to avoid getting tripped up. Ha ha.
Hi Void,
The problem in getting any meaningful results is that the useable capacity of an LA battery is clearly very dependant on the condition of its plates. Repeated load test cycles conducted with short intervals between them will show small improvements until the battery condition stabilises, which can take many cycles. Starting a series of test cycles after a few days rest will again exhibit the same general behaviour. The other problem is that equally timed re-charges from set voltage data points do not return equal amounts of capacity to a battery, so with non-linear charge and discharge curves, attempting to scientifically establish that there is a real FE effect when experimenting with LA batteries is in my opinion futile given battery vagaries.
Void,  there are " battery charger" studies : with-/ out software controle
By LA-batteries : memory-effect,  the first load DOD sometime decides!
seychelles
THE MOTHER AND FATHER OF FREE ENERGY IS EFFICIENCY AND
ONE NEED TO KNOW WHERE THE ENERGY IS COMING FROM. So ansi is
half correct, so here in Seychelles it is bloody hot and 80% humid, so the energy
is already available from the ambient air.. The air con is a very efficient heat pump.
I rest my case SOORY STIVEP..
Belfior
Well this was something I wasn't think I ever see. Egyptian djed pillar made out of stone
https://www.youtube.com/watch?v=-cPuMugnCvQ
maybe tesla coils or other coil under it. I never believed djed was a battery, but a series cap
Ansis
About Bedini and LA batteries.
I work much with accumulators and everything which is done by Bedini is BS.
Sorry fans, I love true.
Battery is simple device and every battery die.
LA die of staying a side.
Just leave it without charging and it is dead.
LA must be Always under DC Current with Voltage which is more! than 6×2.1V=12,6V.
I have 13,2V on battery in Winter time always.
I use LM317 chip which works beautifully.
With Voltage allways connected LA battery can work 5-7 years.
Death is comming if we drop LA battery with Undervoltage.
It is 10V.
Never do that.
There is Rick Friedrich.
Listen about Bedini from him, BUT!!! He is sometimes shoot BS too.
He is right about plate deformations.
All other his theories is sometimes right sometimes BS.
Be wise!
Always!
