Ansis
Did you see my "yellow" picture?
There you see 2 generators.
One 50Hz, second is Auto Car Induction coil which is for Spark generation.
I think all is working with 50Hz frequency for "water pipe" energy sucction from the grid.
Yes, yes, I know.
We must proof or reject that.
Thats it.
Ansis
To Alien.
There is Battery.
Of course.
No FE.
But!
Stimulation is only small amount of energy and there must be loop for recharging.
Void
Quote from: Hoppy on January 20, 2019, 05:07:07 AM
Hi Void,
The problem in getting any meaningful results is that the useable capacity of an LA battery is clearly very dependant on the condition of its plates. Repeated load test cycles conducted with short intervals between them will show small improvements until the battery condition stabilises, which can take many cycles. Starting a series of test cycles after a few days rest will again exhibit the same general behaviour. The other problem is that equally timed re-charges from set voltage data points do not return equal amounts of capacity to a battery, so with non-linear charge and discharge curves, attempting to scientifically establish that there is a real FE effect when experimenting with LA batteries is in my opinion futile given battery vagaries.
HI Hoppy. Thanks for the comments. Yes, as I mentioned previously, I am aware of all of those
factors and taking it all into account. Also, as I mentioned, in the last couple of months I have done
about at least 40 test runs with my test arrangement with small variations. I therefore of course
have a very good idea of what is within normal variations for the battery and setup I am testing with and
what is not. :) I also mentioned that I am not attempting to draw any conclusions at this point, so
relax mate. :) Everything is well under control and very scientific. Couldn't possibly be more scientific. Ha ha. ;)
As I said before, if I think I see something that looks potentially interesting, I will try to scale it up
to higher power if possible, and with higher power I should be able to analyze better. Despite
what you say, if you leave a test setup using a battery running appropriately long enough with a reasonable load,
it will most definitely separate the wheat from the chaff.  I won't attempt to draw any definite conclusions without
doing all the appropriate testing first. You probably won't find a more cautious experimenter in this area than myself.
I don't try to draw conclusions unless there is very good reason to. Everything is well under control.  ;)
Hoppy
Hoppy
Quote from: Ansis on January 20, 2019, 11:21:44 AM
To Alien.
There is Battery.
Of course.
No FE.
But!
Hi Ansis,
If there is no FE why is Kapanadze putting on these elaborate demos?
