0 Members and 28 Guests are viewing this topic.
Ansis
I post it here again?
I posted it in Overunity.com, but where?
OK. Take it.
Ansis
AlienGrey
Quote from: Ansis on January 20, 2019, 04:28:30 PM
And Kapanadzes original? picture too.
Yes I have seen that paper on another posting you made but not on OU  :o 8)
but thanks anyway. It's certainly an interesting idea. but not enough information he obviously knows much about stuff than us mushrooms in the west, kept in the dark and fed BS that's us!
Belfior
I don't agree that we need to charge&discharge batteries. I think we need to charge a cap with a battery, but then use that charge to do something and not let it go back to the negative rail.
If you charge a cap you just made the battery terminals a bit longer. You lost something in the resistances, but you didn't send mass charges into the negative terminal thus destroying a part of the polarity&potential. You need to remove the perversion from the circuits and that is the return line. You gotta to be a wizard to make up for all that energy you just used to destroy your own battery.
I think you can pretty much use any device for OU, if you just stop destroying your own power source.
Is there a way to raise voltage and then zap it back to the source? Connecting positive to positive has no effects, but what if you zap back something like the displacement current?
positive terminal -> DC pulse -> coil -> diode -> load coil -> cap plate1 so then we got load coil or cap plate2. one we use for load and one we use for recharging the battery
Ansis
About" FE" battery tale.
All Bedini's and Beardens and others show something which is not exist in real life.
All they's motors, wheels and others kind of "magic" works in "no state" situation.
In real life, which is charging and discharging of Real Current, the only think which can save
accumulator today is to put parallel supercapacitors with accumulator, but price and selfdischarge is
situation when all that together is BS. :)
There is 2 bad situations when battery go dead.
First, battery is overdischarged with heavy loads+heat+physical damage of battery.
Second is scenario when battery work in soft mode without recharging properly.
To avoid that, we use proper batterys and chargers.
Some peoples use HiFrequency to "rejuvenate" battery.
It is BS.
When LA is sulfated, that is finish.
There is no real possibilities to make it new again.
I spend more than year to "play with magic devices", it is BS.
