Void
Quote from: Belfior on July 08, 2018, 05:03:56 PM
Hah! Even TheOldScientist agrees with me. He is even saying "try to understand what I am saying!"
His input is 7V and some amps for covering copper losses. He is charging a cap with 165V. With that input. So how many Farads you need to run selflooped with 165V?
Hi Belfior. It is not about comparing input voltage to output voltage however.
It is about comparing average input power to average output power.
It takes power to charge capacitors. People sometimes forget this in their enthusiasm.
Having a sparkgap and/or earth grounds in the mix could possibly/potentially allow pulling in extra energy from the environment however.
We should not try to draw any conclusions from any test which is not self looped or which does make an accurate
measurement of average input power and average output power.
That should be every free energy experimenters motto to live and breath by. :)
Belfior
so if the secondary is looped with a cap so they are in resonance, then the cap will charge immediately, because there is no resistance?
You could charge a 9000V cap instantly with 7V input and maybe 200mA using a tesla coil or a flyback. Then if the freq is high, then the cap charges 200k times per second. That is a lot of charge going in, if the output side (trafo&inverter&mains voltage?) pulls 230V 60Hz
TheOldScientist tried to tell the viewers to try to understand. He basically says "if you can charge a capacitor to 165V with 7V 200mA input, there is a lot of charge there!"
Hoppy
Quote from: stivep on July 08, 2018, 04:35:21 PM
Please read my  answer to Hoppy up there
You can always have one physical and another  virtual ground  and.... elevation potential .
Watch my video  again please my friends
I actually posted how to build traditional first version of TK with spark gap. I just did not point at some details .
Wesley
So are you referring to the elevated 'washing line' from tree to roadside in Kapanadze's garden green box demo as the virtual ground and elevation potential?
Void
A couple of Kapanadze quotes:
Kapanadze - at 8:38 in the 'Green Box' video demo:
"Some think that the device uses stray currents.
I would argue the opposite.
It is not of travelling fields and stray currents.
There is one thing, we take the energy from the environment.
The unit is assembled on the principle of Tesla."
Kapanadze - at 55:05: in the 'Green Box' video demo:
Between us speaking, grounding it is not required.
Instead of grounding, it is necessary to use a small circuit.
Hoppy
Quote from: Void on July 08, 2018, 06:01:27 PM
OK. I'll take that as a tentative yes. Wishing you a safe journey.
