F6FLT
Quote from: Ansis on February 21, 2019, 09:23:28 AM
Maybe Kapanadze use Ground to charge Battery inside his box?
Maybe Direct Current is the answer?
If LongWaves is hunngry for Ground and we know AC of 50Hz is dependant from Ground(it is main reason for stealing electricity from Grid companies of HiVoltage from 220V in East, it is in East because of dependency of Voltage potencial for better efficiency of steeling!!!). Maybe there is some anomaly? Maybe there is potencial(from or 1 point), from which start avalanche SuperMega Stealing?
Be free to think like that, because we are investigators!
LongWaves is not "hunngry for Ground", it's just a question of engineering, not of principle. In any case for long waves, the second pole is obtain by a long wire. But at 50Hz, we are no more in the "long wave" range (30 Khz to 300 KHz), we are in the very very very long wave range (6000 Km) so that we can't have an efficient "second pole". We are no more in radio frequencies, and only in the near field (field directly linked to nearby conductors, almost not propagating). It's almost impossible to produce efficient propagating waves at theses frequencies.
stivep
PART 6.
SURFACE WAVES:  WHAT ARE THEY? WHY ARE THEY INTERESTING?
For us  understanding surface wave is the key to electrical energy for free.
When we talking about Schumann waveguide  it is not important what is energy level
at fundamental 7.83Hz  Schumann frequency  and its harmonics.
We only need to remember that  wee need to be at lowest Schumann frequency harmonics we  are physically able to be.
when we  go with frequency of our Rx,Tx pair or  just Receiver,  into 18kHz or lower than  our reactive losses are  the smallest.
more  is explained in article:
https://www.armms.org/media/uploads/1259319847.pdf
and less interesting but useful article :
Isolation of the Zenneck Surface Wave
http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.651.4359&rep=rep1&type=pdf
Please remember that experience with Zenneck wave as A to B  transmission will be needed to
extract energy from Schuman waveguide.
Mechanism is almost the same.
Naturally   present surface wave in the interface   has different frequency ,  phase  and needs polarization
and impedance match at the receiver Rx  side. ( your FE).
Tariel Kapanadze and his clones ( SR193, Akula, Ruslan) used structure   that I name active probe.
the term Active probe is used in patents of James Corum  and Corum Brothers.
A  surface  wave  requires  an  interface  between  two  media  as  it  exists  partially  in  both.
Therefore  if  the  electric  field  is  unable  to  penetrate  into  one  of  the  media,  a  surface  wave
cannot  propagate.
This  could  therefore  imply  that  the  skin  depth  is  proportional  to  the
magnitude  of  surface  wave  produced  and  indirectly  proportional  to  the  magnitude  of  space
wave produced with an exponential dependence.
It is from this concept that the definition of the 'surface wave region' was derived.
Zenneck Wave  does  not radiate in Far Field and is in form  of TEM in TM mode
Wesley
stivep
There are plenty of mechanisms allowing  to build  electrically  short 1/1000  of lambda resonating structures  such as  Kapanadze and its  clones coil.
mkjekyll contribution  is: https://patents.google.com/patent/US3083364
This contribution is important as  explanation of means of electrically short
coil (caduceus  like coil structure.)
Means of bifilar winding with proper spacing
have been explained   in the language  of 1963 antenna science, but for us
important is  to point art   of  physical application.
Electrically Short  HV  part of Tesla Coil is Kapanadze coil.
Small size is our goal.
You retain similar to full size structure  parameters  such as  desired frequency , amplitude, impedance, and able to maneuver proper polarization.
What one must understand is:
Kapanadze trick with  9V battery can  ( but not must) be seen as coupling into energy of another system
By activating active probe that is "immersed" into that system.
By trying to keep language in   level of average reader  I 'm in must to use  words that I try mark as
".. " or ( ..) or active probe.
But I'll try to use active probe word with  proper explanation.( explained in sections 1-5)
Much easier to explain it , would be to use example from classical mechanics, however
it will be only graphical form  that in the sense can not serve as quantum  related.
Let's say you  have slightly  vibrating  hot water pipe, and you clamp it is certain point.
You may see that   pipe start to resonate mechanically with quite increased  amplitude.
Only energy to find the right spot for the clamp, was delivered by  You.
You do not need to pay for pump and water.
At the end of the cycle, of the pump action the motor rotation slows and vibration of the pipe, can reach its damaging maximum.
Active probe operates based  on the same logical concept:
Lets   place  energy  that is paid by someone  but not you, on the same level as  natural energy that is
created by nature  and is not paid by you.
Wesley
stivep
PART7
1.
This is very easy explanation to almost every  nontechnical reader  of basic  antenna futures.
https://www.pulseelectronics.com/antenna_basic_concepts/
2.  Tesla coil  is made out of two coils:
a. low voltage coil ( usually at the bottom of structure)
b. HV  coil( usually inside  of low voltage coil)
- is air/ ( can be vacuum) based resonant transformer.
   (can be called  air transformer)
   (some of variations of Tesla coil can have  more than  one low or/and high voltage coils)
2a    If we place inside of low voltage  coil, the coil (HV) that is in length  shorter than
        corresponding to given frequency required physical  diameter  (e.g Tariel Kapanadze coil)
        it means that we compromised  some of parameters  of  aperture of suitable HV coil.
        https://en.wikipedia.org/wiki/Antenna_aperture
        This may become very much  positive and fulfilling our expectations, as we care only about  certain
        properties ( certain effect) of such antenna or coil manifesting its usefulness.
2b.  Antenna Efficiency
QuoteThe efficiency of an antenna is a ratio of the power delivered to the antenna relative to the power radiated from the antenna.
       A high efficiency antenna has most of the power present at the antenna's input radiated away.
       A low efficiency antenna has most of the power absorbed as losses within the antenna, or reflected away due to impedance mismatch.
However this quote from above can be very much  misleading .
       You may  have, very, very small antenna ( 5cm/2inch long)   perfectly resonating at 1/100 of y(lambda)
       and full size   antenna  (10m long/ 393.700787 inch) perfectly resonating at 1/4 of y.
       The efficiency   of both antennas is different. But both are  performing  well.
       It is the conditions( very specific parameters that we may be interested with) that matters .
       In our case we are interested in antenna  that is small in size and we do not care much about losses created by small size
       of an antenna
       http://www.antenna-theory.com/basics/efficiency.php
2c.  In our case (2b)  we have in mind passive or active structure.
      if passive antenna ( in form of e.g Tesla Coil) is used  - it is  used as Rx not Tx antenna.
      We care not much about efficiency of the antenna as we assume that in given point
      we have plenty  of energy for that antenna  to resonate with.
2d. In our case (2b) if we use  active antenna ( also known as active probe) than
      you need to read my notes about active probe in
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg531943/#msg531943
      and everything that is related to active probe in PART 1 to 6
3. Such structure does not deffer much from  typical  antennas in regards to:
a- ability to be build as resonating structure at 1/2 y , 1/4y  1/100y 1/1000y and so on.
b- ability to accept delivered to its input frequency that makes existing structure   to resonate at  1/2 y , 1/4y  1/100y 1/1000y
    and at its harmonics ( important).
4.
    you must first resonate than radiate.
    this is mandatory requirement to everything possible in air transformers employed  as " let go to all of it " ( passage) of  signal.
5.
Receiving antenna can be build  exactly the same  as transmitting  antenna .
   Rx- receiver      ( abbreviation )
   Tx- transmitter  ( abbreviation )
Wesley
stivep
PART 8
Each lightning burst creates electromagnetic waves that begin to circle around
Earth captured between Earth's surface and a boundary about 60 miles up.
Some of the waves - if they have just the right wavelength
- combine, increasing in strength, to create a repeating atmospheric heartbeat known as Schumann resonance.
Wesley
