0 Members and 23 Guests are viewing this topic.
Quote from: F6FLT on March 17, 2019, 07:45:23 AM
Remote energy transmission, either thanks to the near field at a short distance that does not greatly exceed the size of the resonant system, or at a long distance by radiowaves beams or light beams, are conventional techniques known since the beginning of the 20th century.
Their efficiency is poor, and implementation is difficult, especially for powering mobile equipment, which is why the industry has made little use of them so far.
It has nothing to do with free energy.
Do somebody think that this kind of science results are unused or not improved since these papers/ knowledge publication worldwide ?
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=Dd&AP=&PR=&PD=&PA=Manfred+gregor&IN=&CPC=&IC=&Submit=Search
F.e. un-/ visible light beams in Terra-/Giga-Watt range( per sqcm)
For example for lunar/orbital/astral "Solar Farming" and 24/365 to earth transmission.
Or as Fusion reactor beam.
Or as welder.
Or for tunnel/channel construction ( stone/rock melting)
Similar research :
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=&IN=Winfield+salisbury&CPC=&IC=
East-/West-world comparison, completing and improving
As "13 years old boy/girl " you can soon begin to change your world  like he did :
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fde.m.wikipedia.org%2Fwiki%2FSebastian_Ziani_de_Ferranti
Age in numbers does not indicate intelligence or wisdome.
forest
I agree Zenneck waves exists but misconception is it's radio waves.
Tesla knew about theoretical explanation of this kind of waves and this is what
we should investigate first. However the notion that it's an explanation of free energy is far from truth.
Free energy is much more simple.
stivep
Quote from: forest on March 17, 2019, 09:35:38 AM
Not only Tesla but Marconi  in 1918 in Bolinas California have been trying to do that what Viziv is doing.
Till RCA with Government  shut Marconi's project down in 1921.
So what I'm doing  is  fallowing Tesla and Marconi steps.
I'm investigating  the phenomena.
TEM Electromagnetic waves  can be polarized  in TM  or TE mode.
I do not see any misconception here.
Free Energy  is much more simple
If you can share you opinion in this area  it will be interesting.
Wesley
mkjekyll
Wesley,
I think the S parameters are important especially if one is trying to determine Brewster angle or whatever proper terminology is for Z wave.
Well lets see if the unit I purchased works on arrival before looking at other options,
Agilent 89441A
however this would likely be a good option if not:
https://store.siglentamerica.com/product/sva1015x/
Thank you for the info on the standards parts.  I am interested in what you think about probes or using SNA cables and adapter, highest and best use connecting DUT?
Brake lines messed with, besides being underhanded evil that is downright lacking in class and taste.  I think that Keshe guy is also a main suppression agent for them or else he would not be able to freely rip people off, he did the same thing to his own worker and this mans gf.  I guess if one wants to be a con man then simply sell OU bullshit.  Like world improvement ministries guy with a rap sheet of cons going back years.   I think they find these scammers and then somehow use them to data mine so everyone who has the answer or is close should take heed.
Had you known what you know now maybe you would not have put your neck out for everyone's benefit but then again it can only be accepted as evidence of success.
When books are burned or other data is censored or buried, this is predominantly for one reason.
If someone here wants to think empirically and wind some coils and attempt some actual bench work; like so many of the amazing people at this site then great, if not comments should be reserved and respectful from the theoretical thinkers who have not yet ventured into the lab.
stivep
VNA uses directional  coupler so if you do not have VNA
but NA you are not is bad situation at all.
So it is must know it and must have it for many applications.!!!!!
#158: Directional Coupler Basics & how to sweep SWR of an antenna | Return Loss | VSWR
https://www.youtube.com/watch?v=iBK9ZIx9YaY
Used directional couplers  you can get for 1 to 5 dollars or less from hamfests, or other similar places.
I know that it sounds crazy to some of you but, don't worry about lower  range written on of them.
typical Directional  Coupler works from  above DC up
Try it.
Wesley.
