mkjekyll
Wesley,
Will the directional couplers rated to 1gHz for CATV work for the low SW frequencies and if so which levels of DB loss will serve better for SWR measurements lower or higher?
Perhaps this is a level of heresy, I don't know just looking for affordable ways to tinker.
Thanks,
Mick
Void
Wesley, guys, I posted some links to some video demonstrations of some other types of devices
by Kapanadze including some different types of disc generators, and an apparent hydraulic generator from 2015.
Apparently quite different approaches/configurations than Kapanadze's coil generators.
See those video links here:
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg532768/#msg532768
Apparently the video at the first link is one of Kapanadze's very first demos. It would be interesting
to know what Kapanadze had to say in that very early demo, to compare notes.
Do you think there could be a common principle behind all of Kapanadze's quite different types of generators
(coil, discs, hydraulic)? If you think there is a common principle behind them, what do you see that might be in
common between these three different approaches (besides possible tricks ;) ) ? If they all work on different principles,
then how could Kapanadze come up with three completely different approaches like that? If they are all working on the same
or similar principle, then what may be common between those three different types of Kapanadze generators?
A puzzle for you.
nelsonrochaa
Quote from: NickZ on March 19, 2019, 11:04:13 AM
   Nelson:   Well, no you didn't clarify the part about self running and self feed back. As most all of the shown self runners are based on a feed back circuit, to keep them going.
   In the video below, translated by Wesley, you are showing a device that needs only a one or just a few second pre-charge to start. But, then it is shown running on it's own for much longer than it would normally be expected from the small 9v battery one second change. As your device was stopped after a short while, I would now have to assume that it does not keep running for much longer than what is being shown, less than a minute.  Is this correct?
     https://youtu.be/mz9NRYQJJt0
    You can also PM me, if you'd rather not discuss this openly. I would understand your position.
Hi Nick,
Nick, I am not going to detail the process used in this circuit, because I am currently disputing in court the intellectual property of this same system, which was retained in Germany by the company with which I was working, but what is demonstrated in this video is not an overunity system, the system was not projected to self run even could self run some minutes , with a resistive load.
It is a Resonant system with some interesting characteristics of "amplification"able to show more work in output than it is input in terms of efficiency, But it is all mere assumptions on my side that would have to be checked in the laboratory with independent and competent entities.
This is a unpublished video where you could see the same circuit without be totally assembled, but show how much power a 9v could store :) and provide output  :) to a 60w 220v motor with a a 2kg metal disc on the load.
https://photos.app.goo.gl/JEYdPrEdXYX8AMHR6
All the best Nick
Void
Hi Nick, my guess is Kapanadze somehow got his hands on a compilation containing a collection
of different inventions for free energy. Maybe some secret document(s) compiled by some department of
the former Soviet military, and somebody passed it on to Kapanadze, or Kapanadze otherwise got his hands on it.
Kapanadze seems to be a very smart guy. With that basic starting information, he was able to replicate several different
types of devices. Either that, or Kapanadze is pretty friendly with some aliens. ;D
That first generator that Kapanadze shows at the first video link I posted seems to possibly be
an electric motor driving a long shaft with several non-balanced fly wheels on it of different types, and
the end of that shaft drives a generator which loops back and powers the electric motor.
This appears to be different than his other disc generators which might only have two discs of two
different types of metal, and which may be some special type of homopolar generators.
Then the hydraulic generator appears to work on a completely different type of setup.
If you add Kapanadze's different coil generators onto that list, and possibly even a car engine that
can run on water, and you get quite a few different types of free energy generators coming from one man.
All of them are amazing on their own, if legit. Pretty mind boggling coming from one person.
So, either former Soviet secret compendium document of free energy inventions, or Tariel talks to aliens. ;D
AlienGrey
    You can also PM me if you'd rather not discuss this openly. I would understand your position.
Interesting video did you notice the black torrid, now that is interesting.
