Visiting their laboratory https://www.tedmagnetics.com/ and getting their development results demonstrated :
                                                     C. O. P.  : ?   Impressed  ?
https://patents.google.com/patent/US20150364979
https://patents.google.com/patent/US20090096219A1/en
https://patents.google.com/patent/US20070242406A1/en
Sincerely
OCWL
AlienGrey
In that case why do it your self ? when you could have PM'd him?
and he has 3 threads with all the same name, I mean! why let anyone post here at all!!
mkjekyll
Hi Wesley,
That's far out, what do you intend your first use of the EScope, checking out core materials?
You must have a large home or a very understanding wife as likely there is gear all over you place.
Mick
mkjekyll
Hi Ianca,
That't the flux switching design used in old puter mag ram memory, also the magnetic boots Radis.  Joe Flynn is said to have worked very hard getting the bugs out. http://www.flynnresearch.net/technology/PPMT%20Technology.htm
Requires a rectangular BH curve material.  Or take a step further with conditioned magnets and then one has the Sweet device.
Samsung is said to make a motor based on flux switching but very difficult to find, not sure if they are allowed out of Japan.
Mk
Active or passive switch devices :
https://books.google.pt/books?id=iwEAAAAAMBAJ&pg=PA102&lpg=PA102&dq=wiegand+coil&source=bl&ots=05KqLezhpG&sig=ACfU3U0SOyaqT2Z6VAQuCZvO8NKvRb5bGw&hl=de&sa=X&ved=0ahUKEwjGvq6hhqHhAhWtyYUKHXyWDu8Q6AEIGzAF#v=onepage&q=wiegand%20coil&f=false
Probably this is the " electromagnetic phenomena" used by him as "coated wire " :
https://contest.techbriefs.com/2016/entries/sustainable-technologies/6390
Flynn brothers research and usefull info https://web.archive.org/web/20040610131607/http://flynnresearch.net/
Flynns company name now : https://www.qmpower.com/
This  is for me the question for getting the right answer and solution  !?
https://www.tedmagnetics.com/energy/wp-content/uploads/2016/05/Results_v4-e1464274784852.jpg
                                   EMP/signal input and output ( kind?)
