Hoppy
Quote from: Void on July 10, 2018, 06:37:05 PM
The 'small circuit' might conceivably be an LC tuning circuit when connecting to a length of wire,
or car body, or airplane body, etc (virtual ground).
We see an old car parked in the roadside fairly close to the aerial wire in the green box video. The camera man pans to the roadside several times as if to direct attention to it.
AlienGrey
Earlier Void was interested in the green box, you might be interested in this posting by whatsup
Try making heads or tails of the circuit  ;D
apecore
Guys,
Will there ever be a moment when discussion about the ground connection ends?
Does it realy make a different in understanding its MO?
In my opinion i find it more interesting to talk about the quotes from Ruslan K posted by Solar lab on the 7th of July.
Some of the highligts....
".. You make the magnetic field longitudinal (pushing) and transverse, creating a flow of motion!
Hence Tesla pushes the current, or in other words, pushes or carries the magnetic field away from the pump by a longitudinal field.
And now make a controlled Tesla! That is, interrupt the pushing of the current at a frequency below the pump. This is the current flow!
You need to tune in and Tesla resonate ... To get a current.
Grenades do not need to be shaken.       Still do not know why and what they do.
You blink one layer long, the other a little shorter. All with one wire. A long coil pumps a magnetic field, a short one removes it.
if there is not enough voltage, do the docks from the converter.
But the output must be filtered by HF. Otherwise, your resonance will swim away"
Greetings
AlienGrey
Just looking through on the net as you do, found this informative video, watch it before it disappears.
https://www.youtube.com/watch?v=26QqUKoQpO4
