0 Members and 80 Guests are viewing this topic.
Comparing the power density from a " nuclear power to heat to electric plant"  with Harry Goldbaums device
https://contest.techbriefs.com/2016/entries/sustainable-technologies/6390
A nominal generator, approximately the volume of two men's shoe boxes, including the battery and control module, can supply extraordinary output.. Even operating at a low frequency of 400 hertz, the net induced voltage is +/- 8.4Kva/sec, (which is an hourly rating of 30.2Mva/hr (40,500Hp)). For comparison, power plants generate from 375 to 758 Mva; a wind turbine generates 2-3 Mva; a large heliostat may generate 280Mva..
show us how powerfull  10 cm x 10 cm x 10 cm [ dividing with 2 men' s shoebox volume and multiplicate with f.e. 29767 KW (~ 40500 hp by 400 Hz propulsion)]  " EMP POWER CUBES " could become !
In this power range motor controler ,inverter and battery charger are in the 1 $cent/W production costs level.
From Euro-currency view and for comparison : $, Hongkong or U.S. ?
1 shoebox dimension : 35 cm x 20 cm x 10 cm  =   7000 ccm
2         "                           :                = 7000 ccm x 2 = 14000 ccm
EMP POWER CUBE       10 cm x 10 cm x 10 cm =   1000 ccm
         29767 KW ( 400 Hz): 14 = more than 2 MW per " EMP POWER CUBE"
I think that 1/100 from 2 MW is for the common household sufficient :
                    " MICRO EMP POWER CUBE" ( POWER STICK )
                     like https://www.logistik-xtra.de/polysteel-600
Taking oeko-energie.de and mtbest.net their " intelligent household" consume numbers,1/1000 from 2 MW is enough :
                                      a theoretical 1 cm x 1 cm x 1 cm cube with 2 KW output( 400 Hz)
                                                        Negative "sink" Voltage energy
1 Wh = 3600 Wsec and by 400 Hz cycling : 3600 x 400 x 2 = 2880000 Wpulse( average, Wpulse peak?)
stivep
1. https://youtu.be/2G8PVTKtOzA?t=528 here is ground wire. (look at picture: ground wire of Tariel Kapanadze electro hydraulic device.jpg                               )
2. https://youtu.be/7JQSyQAVqzc?t=849  this combustion engine  is HHO operated ( exclude this part  of video  please)
3. https://en.wikipedia.org/wiki/Homopolar_generator in parts of video where Faraday disc is  shown , it is to amuse the audience. ( ground wire is not excluded)
4.  https://youtu.be/7JQSyQAVqzc?t=1299 here electric motor is  powering Faraday disc, and Faraday disc
     is producing synchronizing impulses for HV Generator only. ( ground wire is not excluded) https://youtu.be/qdJ1V_yDv-c?t=651
     It fits my explanation about active probe. https://youtu.be/yNs2wc8nRJw?t=261
5. https://youtu.be/7JQSyQAVqzc?t=4296 ( ground wire is not excluded)
6. https://www.youtube.com/watch?v=mG_FsBn2qxk capacitive   active load coupling used many times by Tariel, Akula, Ruslan.( look at picture below)
    so the wire has  two functions:
   - capacitive coupling ( not required when  real ground is connected)
   - when real ground is used : tuning circuit (The LC circuit) between ground and LC oof the coil.
7. verification  by Stefanov  of ground wire: https://youtu.be/e_kXFGNdANU?t=429
    short story:
Quote from: Void on March 25, 2019, 01:07:06 AM
Kapanadze has also claimed he had an invention of an internal combustion engine which ran on water.
Do not confuse two of them. HHO is different concept.
Should we ignore all of that because it doesn't fit in with someone's preferred speculations of how his devices work?
That is a serious question.
That is correct.
Receiver is more  forgiving. I does not have to  look like traditional  Tesla Coil.
Wesley
mkjekyll
Backing up a little as another member brought up the TED device from Wesley's video mentioning Ted Annis.  I would like to present the "missing" source of the energy for everyone to dig into.
https://earthsky.org/earth/mms-data-new-event-magnetic-reconnection-plasma
https://science.energy.gov/news/featured-articles/2018/10-03-18/
https://www.americanscientist.org/article/reconnecting-magnetic-fields
stivep
mkjekyl
some addition to magnetics with regards to Ted Annis
Quote//Dr. Prat-Camps said: "We have created the first device that behaves like a diode for magnetic fields.//
//or to make one magnet connect to another without the connection happening in the opposite direction.//
https://m.phys.org/news/2018-11-defy-19th-century-law-physics.html
Wes
