stivep
did you  wind coils  of magnetostructive rod  -(points  1 to 5)
for each given material permeability is given.
http://www.free-energy-info.com/Smith.pdf
go to right page.
QuoteMagnetostriction (cf. electrostriction) is a property of ferromagnetic materials
that causes them to change their shape or dimensions during the process of magnetization.
The variation of materials' magnetization due to the applied magnetic field changes the
magnetostrictive strain until reaching its saturation value, λ.
https://en.wikipedia.org/wiki/Magnetostriction
Wesley
We  are living in a "design"- world : https://newatlas.com/gold-melt-room-temperature/57327/
Fullerton worked with 200.000 Ampere bursts to change " conventional structure".
             sentire( to sense), fuehlen( to feel) power density :
https://contest.techbriefs.com/2016/entries/sustainable-technologies/6390
2 shoeboxes total ( battery + controler) , but net the generator only 1 shoebox-dimension for xxxxxx KW output.
One cube, 1 cm x 1 cm x 1 cm : 2 KW output, by related cycle process frequency.
It is time to make this " generator" 3d-printable.
1 cm x 1 cm x 1 cm : 2 KW x 24hpeak= 48 KWhp per day
human individual body cooling / heating energy need. : 12 W
MDI Dome,112 sqm : 2400 W heat peak by 400 W electric heat pump ( -20 °C ambient condition )
Electric multimotor-gear car 1 KWh/ 100 Km , 150 Kmpeak velocity( 130 Kmpeak street legality)
Electric intelligent household power need per day : 3 KWh ( /24 : 125 W )
kolbacict
There are only ferrite rods. :'(
But what is (positive dc input)?
if there is no way for it. is a capacitor in the path? :)
Quote from: kolbacict on April 04, 2019, 03:47:09 AM
Can you, kolbacict, define -by eye - in " solar ink dots" the capacitor/condensator ?!  ;)
1 cm x 1 cm x 1 cm compact " solar ink dots" -cube output compared with 2 KW 1 ccm cube  !?
Goldbaum device : " coating" ! Material,physical emf effect !?
kolbacict
this circled in red. if it were not there, a cascade with a common base would result.
