0 Members and 83 Guests are viewing this topic.
stivep
Kapanadze is seen as  Rx-receiver only.
Energy fluctuation  in Schumann waveguide  is manifested by Schumann resonances frequencies.
That alone must impact waveguide boundaries( walls)
(Slotted Line - is  a must to understand for  sensing such fluctuation in waveguide.)
Naturally present in interface Surface Wave in Schumann waveguide is exactly the same as that of Viziv. (TEM in TM mode)
The interface is earth/air " 2D space"
The only difference to  Viziv is that  this energy is receive it only.
Wesley
Kator01
Quote from: stivep on April 06, 2019, 09:13:06 PM
https://www.youtube.com/watch?v=66tEd-qh6dQ
Some interesting play with Avramenko
Wesley
Interesting play....emphasis is on "play"
Systemtic measurement-error : He measured open-loop voltage and not Voltage under load ( inner resistance
of intrument is the load while measureing current )
So the calculation of power is wrong.
Additional error might be bandwidth of instrument.
Mike
#2534 mkjekyll :
when                 1 coil x     1000000 coil turns x 1 Ampere-turn ~ revolution = 1 Mio. A
or.                      1 coil x        1 coil turn x 1000000 Ampere-turns=                      1 Mio. A
so are the same
                           1 coil x    1000 coil turns x 1000 Ampere-turns=                       1 Mio.A
                     (    dividing in 10 , 100 , ..coils x coil turns x Ampere-turns )
The Kunel- bearing device , a bearing in a bearing, so 360.000 mechanical  revolutions divides in 600x600 mechanical "revolution each "-stages would mean less friction and less wear ! Available ?
Kunel- amplifier device, factor 10: 10 Ampere- coils
More or less "Mass" : coil mass in Kg or more or less "Speed- velocity" in pulsed  Hz cycles
AlienGrey,many "Puzzle"-parts will change the future :
https://www.google.com/search?q=24%2F7+power+transmission+drone&ie=utf-8&oe=utf-8&client=firefox-b
+ flying "Viziv"- Transceiver
+ 24/7 flying solar-/ wind- energy-glider f. e.  http://airhes.com/
But this is only for on-grid consumer,industrial and private, important.
Off-grid net-architecture is with less over-head costs, 50% cheaper.
Sincerely
OCWL
