mkjekyll
lanca,
This Kunel coil sounds fascinating along with the iterated bearing concept, can you provide some links or PDF's with some in depth info? I think I recall something from the Kelly free energy book about Kunel but likely your data would be more stable.  There The future will likely be some type of hybrid bearing with the magnetic part and rollers or balls when load overcomes the magnets repulsion.
here is a quick quote concerning bearings and mag repulsion motors
http://wheelerfluidfilmbearings.com/advantages-of-babbitt-bearings-and-sound-babbitt-foundry-practices/
https://www.ijedr.org/papers/IJEDR1701064.pdf
mkjekyll
lanca,
with the multiple series  coils if inductance the same they can still be different phase, use RF trick to get dBi antenna gain then PFC.  This is reason TK uses motor disconnected, it is running like rotary condense correcting PF.
Yes the ratio multiplier trick if phased properly should work, good idea, give it a test!
https://patents.google.com/patent/EP1501174A1/fr
It is not the device for itself which makes power management "complicated", it is the charge/ load relation or ratio.
In Europe the net-grid consumer frequency 50 Hz( a 2 signals) =
                                                            3000 RPM or 50 RPS =
                                                        1 Rev/Hz, 1 Rev/2 signals
https://worldwide.espacenet.com/publicationDetails/description?CC=US&NR=2012256422A1&KC=A1&FT=D&ND=3&date=20121011&DB=EPODOC&locale=en_EP#
       [0092] 1 W.           /Revolution per minute
       [0093]  0,25 W.    / Revolution per minute
       [0094]  0,01 W.     /Revolution per minute
                     hertzian cycle amplitude and frequency and duty cycle modulation
                       in rotative - motive or generic - devices or static= non moving parts device !
http://spiff.rit.edu/classes/phys213/lectures/amp/amp_long.html
https://translate.google.com/translate?hl=de&sl=auto&tl=en&u=http%3A%2F%2Fwww.arestov.de%2Findex.php%2Fde%2Felektromotoren%2Fwindenergie
                                                 before : singular /after : plural ( double, triple,....) coils
                                                 "Example : a wind turbine with nominal 400 W .... "
        ? Watt / RPM
                                                  before :               at 20 m/ sec                  70 W
                                                  after.   :           at 10-12m/ sec.               320 W
                                      Less input pressure/ force/ energy but more output energy/power
                                        20 m/sec = 72 Km/ h wind velocity : 70 W output  :P from rated 400 W
mkjekyll
lanca,
Thanks,
I will have a look when I have more time but it looks very interesting, the French patent app.
We could also do much better just driving high impedance windings for very high voltage and stepping it down loose coupled to overcome a lot of the drag associated with the Lenz law.
By the way some might find interesting the magnetic design of the Alexanderson alternato, Don Smith was an interesting character.
stivep
my new  Electron Microscope
https://youtu.be/64oFAQMCVAA?t=870
Stability  of  the power supply is 0. 0007% That is much better than required for   electron beam plasma accelerator.
Wesley
