GeoFusion
PolaczekCebulaczek, and all
How should I enlighten on this...
dont' discard it..
Resonance plays a very important  role on energy conversion devices but is not what brings that additional
external energy into the system(s).
That  what brings that extra energy that we want to know about, where it comes from and how to use it...
comes from our SURROUNDINGS.  How?
You will need HV IMPULSE, SHORT BURST, Continuous. simple Kacher wont do this on it's own.
Excitation of the particles.... they are in our space and everywhere.
The receiver coil must resonate with the HV impulse module ( coil ) to able to harvest that what comes
and collects 100% of the energy. Here is where Freq management is important, it will very for everyone.
its like having a radio station and try to tune your radio receiver to the transmitting signal.
Imagine A field being generated with HV and having to Collapse it abruptly right after and forcefully,
that is one way to create this condition.
This energy we could also view it electrostatic since it EMPs everything as well.
This is what charges the caps right away and fast.  Ionizing.
  by modulating that signal coming in it can be amplified with a secondary circuit.
"""LIGHTNING""", the discharge, The Ionosphere where many of the charges are flowing..
is our example of where this energy is coming from and it is abundant and infinite...
filling our planet and outer space is totally seeded by this.
Just need to know how to activate/excite these charges and make them usable.
Tesla coil needs to operate as HV Spike discharge device,
imagine like a Knife wave with a sharp drop to kill the oscillations
and repeat. as exmaple. It's this collapsing field which is making this exciting condition
It can be done with any other setups as well as long as it does this.
Vasmus was one who did it also,  the relay helped well and his modulation circuit.
Ruslan did tell some years ago on a russian forum what it was when he was new to this,
he did say it is all about Tesla coil, the main ingredient.
So there are many others who had shown but did little or nothing on Knowledge.....
Cheerz~
forest
Not ions but electrons which are here but are "dormant till cycled" like Don Smith said. I still cannot understand how Don was able to  present so much correct information with so much mess around. You can re-watch his videos a catch some elements on schematics which he never explained but they are here. Look for example at secondary - how he showed it on actual devices and how it was represented on schematics.
It's incorrect to think that all such devices are made by people at garage. Look what happened to Barbosa & Leal... The energy source is one, quite complicated in fact with direct connection to Sun. All you have to do is connect all dots , all tips from inventors from all times...it was enough for Barbosa & Leal to make devices producing COP=100 but they made a mistake when presenting device powered from power grid.
AlienGrey
Hi I my self got so fed up with all the BS on the subject I made a test rig for experimentation with
a fast NE555 and a MOS-FET current driver.
I first wound a miniature coil wit about 600 turns on it for L1 and L2
just had 2 or 3 turns it was quite good at that and would illuminate a LED 5Watt display as a load,
I also wound a bigger coil to play with a few 100 turns for L1 and L2 was 1/8th wave and tuned it to
the winding wave length with far better results
I used a 'c' across L2 secondary winding, wire length is critical for this device.
Here is the LF test rig I used
AG
Acca
Here in Russian is the "RUSLAN K." "mindset" of why he is the way he is.. looks like he is afraid of the collapse of the World system as he sees it...
This is a conversation with Polish guy.. Every one will just have to translate too him self, as Russian is hard to do a proper cut and paste google translate.. Sorry for that..
Acca...
Ruslan K 7 months ago
Для того чтобы этот аппарат запустить и он полноценно работал, прежде всего надо понять как работает электромагнитная волна. Затем разобраться с катушками... Каждый делает ошибку огромнейшую не понимаю как работает эта катушка. Мотаю не понимает вообще сути процессов и как это работает...! Есть ещё один товарищ сталкер который лечит мозги всем не понимает также ничего, я абсолютно ничего не сделав! Ни одного готового образца он не показал !!! Зато Болтунов развелось целая куча, никто не хочет думать головой а только одни оскорбления. Поэтому я и перестал всем рассказывать что и как...! Это ваша ошибка многих кто зубами скрипит и гонит, тем более оскорбляет. Поэты причине вы ничего не знаете будете дальше скрипеть зубами! А это очень просто всё сделать...! Надо только мозг включить
Walery Makarewicz 4 months ago
Руслан, ты прям как Капанадзе становишься. Всё намеки да коммерческая тайна. Че вы понять не можете что нужна инструкция по сборке и НАСТРОЙКЕ. У тебя получилось сделать самозапит. У Сталкера хорошо получается обьяснять материал. Ну так начните сотрудничать между собой - обьясни все Сталкеру, может у него получиться обьяснить все народу. Ведь большинство пользователей и так не будут понимать как работает генератор, а производить и продавать его массово просто не дадут. По-этому ни денег ни широкой славы затаиванием СЕ не добьетесь. Посмотрите на Н. Теслу - ему закрыли рот, обрезали финансирование, а потом забыли...
Ruslan K 4 months ago
Walery Makarewicz не не ...погоди ! Я не буду никаких инструкций писать . Эта вся херабора настолько проста что дальше некуда. Но если вы инженер, занимаетесь экспериментами и хорошо знаете что такое электроника и как движется ток . Что такое волна и как она себя ведёт в катушке, этот аппарат вам по силам !!! Если вы ждёте подробных инструкций... увы ! Нет и ещё раз нет. Это всё равно что дать обезьяне автомат .
Может и так, но по моему атомные электростанции, войны за нефть, голод и т.п. - вот это автоматы похлеще ... И все-таки без схем, инструкции настройки, инструкции безопасности это так и останется "гаражной" технологией. Капанадзе сам говорил, что он даже Саакашвили установку показывал и что? и ничего, ... официальным властям это просто невыгодно. Они бояться потерять контроль над счетчиками, власть и деньги. Ну ничего, остается надеятся что однажды такой как Ацюковский Владимир Акимович (спец по эфиродинамике http://www.atsuk.dart.ru) напишет книгу и выложит в открытый доступ.
Вы странный человек ! Никто ничего не выложит. будет катастрофа !!! Вы обрушите систему.
Какую систему? Систему, которая стоит на нефти, загрязняет и уничтожает природу, убивает сотни тысяч людей? так она и сама скоро рухнет. Будет безработица? Так уже сейчас роботы заменяют людей, по-этому проводят соцэксперименты по минимальному доходу, который выплачивают просто так - ни за что. Война? А разве сейчас мир на Земле? Сейчас в мире насчитывается почти четыре десятка вооруженных конфликтов и войн. БТГ это только одна из технологий, которые возникнут благодаря теории эфира. Просто возникнет новая социальная система, как когда-то возникали новые системы с открытием колеса, парового двигателя, электричества и т.д.
давайте не будем писать глупости ! Человек , это алчное создание . Я сейчас выложу подробности и начнётся бардак . И сразу же всё запретят. Потому что начнут продавать гаражные мастера это всё в массы. Причём рукожопые мастера , а таких тут пруд пруди. Это будет такая жопа, что пострадают простые люди. Нельзя так давать просто человеку с корыстными целями. Успокойтесь ! Я лично сам с 2013 года ночами не спал,занимаясь этим всем. И как любой другой, ценю свой труд. Потому подсказываю как могу,но подробно разжевать это будет слишком не просто и к тому же я сказал что не всем это должно попасть в руки !!! Не всем !!!
Таки да, наверное Вы правы - человек это алчное создание. Тогда появляется вопрос - сейчас под воздействием Вашей алчности, не уводят ли Ваши подсказки на ложный путь близких к открытию искателей СЕ? Ведь теперь они по логике алчности рассматриваются как конкуренты? Ну да ладно, на нет и суда нет. Приятно было пообщаться с создателем БТГ. Удачи!
Я не занимаюсь уведением в сторону ! Я хочу чтобы инженеры начали головой соображать, а типа "радиолюбители " (Деньга - любители) вредители отделились скрепя зубами. Вот что я хочу ! Пока на всех видео что я вижу и читаю тексты...Всё тупик и глупо ! Люди не понимают что такое генератор переменного тока. Не понимают и не хотят . Что я могу сделать ? Вот давайте к делу сейчас все.... Допустим ! Ответе мне на вопрос : Что такое Тесла и для чего она нужна в установке ?
Yury 38 4 months ago
Ruslan K Руслан привет!, тэслой в этой установке мы создаём свободные насители зарядов ,а бифом утилизируем в колебательном процессе;)
Ответ не верный ! Я вам про воду говорил ? Предметы на воде становятся легче ? Включайте соображалку . Магнитное поле вращающееся в индукционке ничего не напоминает ?
Ruslan K ок как писал Тэсла " эфир нужно охладить, создать зону малой энергии ,тем самым эфир сам потечёт "к центру его трансформатора , примерно так?, я в опыте обнаружил влияние на колебательный контур от индуктора каторый просто качал транзистором, на ослике появилась ам МОДУЛЯЦИЯ, нагрузка загорелась ярче! Это оно?
йожын збажын 3 months ago
Walery Makarewicz он не становится, это один и тот-же человек, если бы эта хрень работала бы он бы сам подробную схему сборки выложил, а раз не вылодил и не запитал от этой зрени сварочник жто значит что все это фейк обычный.
саня клерк 1 month ago
НЕТ ! свободные носители зарядов ( это нам выполняет индуктор - а стоячая волна - ох как любит этот индуктор ))))) и не какой утилизации не происходит ( иначе это гибель для прекрасного момента ) просто --- используем работу этой красоты !!!! чем мог - чем мог !!!!!!
саня клерк 1 month ago (edited)
как писал Тэсла " эфир нужно охладить, создать зону малой энергии ,тем самым эфир сам потечёт "к центру его трансформатора , !!! ДА!!ДА!!! ИМЕННО ТАК !!!! ---- но вот есть одна закавыка ( только когда вы - соберёте дэвайс и потом разберётесь как это работает --- вот тогда вам будет ясен смысл вот этих слов (нужно создать зону малой энергии ,тем самым эфир сам потечёт "к центру его трансформатора)))))))) единственное что могу от себя добавить (зона малой энергии - это нашей современностью будет непонято ) !!! про цитирую нашим пониманием - дней наших ( активный вакуумный ноль или зона минус 1. с + 1 НАПРОТИВ или вакуумная исходная точка или (+0-) или ЭНЕРГЕТИЧЕСКИЙ ВАКУУМ двух полярностей ! эпицентр вакуума !!! намекаю как могу !!! зона дефицита энергии или чем мог - чем - мог !!! это похожее как у нас - у людей все и всё на приделе ( но ) взрыва не будет ! построили границу и обмен дефицитом
