0 Members and 71 Guests are viewing this topic.
gyulasun
Hi kolbacict,
It is good the circuit oscillates in practice when built from a correct schematic.  In the circuit simulator, have you tried to flip the wires of coil T1 ? (or T2, it does not matter which of them)  Or what coupling factor did you choose between T1 and T2 (mutual inductance)?
Regarding the common base single transistor stage its voltage gain can be much higher than 1 so basically the simulator should work also.  What is the number of turns for T1 and T2?  Try to increase the number of turns for T2 if it happens to be less than that of T1.
Gyula
stivep
Similar concept is proposed by guy who is close to hiding  himself "chip"
Wesley
kolbacict
 Hi.    A factory rod was taken (LW, MW; radio receiver magnetic antenna). contur coil.
As it is not surprising, the generation is available for any connection. (flip)  :)
stivep
https://www.youtube.com/watch?v=9yFTWQXY1oI
  18MHz  800V
Russian military tube used  in generator is GU50.
The end of the rod is made from graphite.
The flame is caused by adding  capacitance of human hand holding metal wire. (https://youtu.be/9yFTWQXY1oI?t=315)
The nature of the flame explained by  narrator is natural presence of Oxygen, Nitrogen transmutating  Graphite.
However  author says that Graphite has nothing to do with nature of the flame and Graphite is only the "victim" of the interaction
Between  O and N,    in presence of HV
Wesley
Note:
no interpretation
stivep
This post  is related to energy conversion using Terfenol D,   and is not in any way related to my post from above:
http://tdvib.com/terfenol-d/
https://aip.scitation.org/doi/pdf/10.1063/1.5006676
Terfenol-D has the largest room temperature magnetostriction of any known material. T
Terfenol-D is a solid-state material [glow=violet ,2,300]capable of converting energy from one form to another.[/glow]
Picture from below shows Ted Annis application of Terfenol D
Wesley
