0 Members and 69 Guests are viewing this topic.
stivep
Quote from: a.king21 on May 10, 2019, 05:21:59 PM
Note: for these who don't understand  the importance of  it :If no-interupting  or overloading  factor exist  the bell  waveform would be infinitely growing.It looks like Stanley Meyer  water fuel cell patentBut "I didn't find exactly that  drawing.
Klystron
Thank you very much https://en.wikipedia.org/wiki/Klystron
I see it as  helpful information.
However  Klystron operates at  HF band  and acts as a valve
But here we have:
1. Low-Frequency Klystron for Accelerator Applications
   https://www.researchgate.net/publication/224287346_Low-Frequency_Klystron_for_Accelerator_Applications
   and that is interesting.
  The low frequency for the article and application   is still quite high  201MHz.
2. The table III sends  us   to 100MHz
3.https://www.sciencedirect.com/science/article/pii/S0031891459905397
QuoteA description is given of a servo, stabilizing the frequency of a microwave oscillator to the resonance
frequency of a cavity, modulated at an audio frequency.
The stabilizer requires no re-adjustment and is designed especially for very short waves and continuous operation
Thee is not much explanation   and audible frequency may  act as  pulse  beat.
so we may  scrap   point 3.
I  see  a.king21 comment as important.
Traveling-wave tube:
QuoteTraveling-wave tube. A traveling-wave tube ( TWT, pronounced "twit")
or traveling-wave tube amplifier ( TWTA, pronounced "tweeta") is a specialized
vacuum tube that is used in electronics to amplify radio frequency (RF) signals
in the microwave range. The TWT belongs to a category of "linear beam"
tubes
, such as the klystron
https://en.wikipedia.org/wiki/Traveling_wave_tube
https://www.revolvy.com/page/Traveling%252Dwave-tube
One of simple techniques is to take CRT from old oscilloscope or old long neck CRT. Cut just the neck( the longer the better.)
Open neck is the glass tube similar to cold catode tube.- https://en.wikipedia.org/wiki/Cold_cathode
The only difference is that  our tube has filament.
We than may at easiest place it in glass jar  and vacuum it, or  heat it  with  torch and  and join it  it to  glass tube from Glass  Pyrex labware,  .
I did  it in the past. It is doable.
The targeted focused electron beam   can  be check  using piece  of fluorescent screen from old CRT or  fluorescent lamp.
https://www.youtube.com/watch?time_continue=3&v=3OgsqhxwGmo
Wesley
PS: But  everything that is big   can  be scaled down. ..well not everything.. waveguide must have real estate  to work.
By that Schumann  waveguide is  space between earth and  ionosphere.
stivep
gyulasun
A klystron needs input power to heat the filament for emitting electrons from the cathode.
Also high positive voltages should be created by a power supply for accelerating
the electrons and to maintain the negative resistance.
So basically this device has a COP < 1 in itself, just like the good old electric valves or transistors etc we use for amplifying any signal.
So question remains where the 'magic' happens if COP > 1 result is forecast?
Gyula
stivep
Quote from: gyulasun on May 10, 2019, 06:35:11 PM
Gyula
There is almost never  COP>1 unless  you dealing with Coefficient of Performance – Heat Pump, Refrigerator, Air Conditioner.
There  is no  overunity.
however  the subject was brought to your attention  by CHAIN OF  INTERACTIONS  STARTING  WITH   ionisation   in presence of hydrogen for
Stanley Meyer that was next compared to Tariel Kapanadze
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg534102/#msg534102
I found common factors  ( similarity) between the two.
Quote from: stivep on May 08, 2019, 01:25:09 PM
Thank you.
the  3 factors:
-HV
-resonance
-ionization
in Stanley Mayer and Tariel Kapanadze  are accounted for.
we also have  electrostatic potential.
By that we can  conclude  that ionization of  the air  when compared to picture ( two links)
showing hydrogen  phases of energy conversion and  Bell waveform  (known   as   trumpet ) can  be  a factor  of must have it!!!
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/dlattach/attach/172822/image//
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/dlattach/attach/172823/image//
-in other words I'm pointing at identification of energy conversion based on its components  e.g hydrogen look at the picture and its  descriptors.
Wesley
a.king21
The RLC circuit is not an effect.  It's a cause.  Phase conjugate mirror creates negative resistance.
Look again at the RlC  circuit. Check the ARRL nomograph .
You are looking for 120 cps. 60 up and 60 down.
Read Gabriel Kron.
Remember Kirchoffs laws are a special case. They do not apply to external magnetic fields.
Nearly every circuit has an internal or external magnetic field.  Use Faraday's law instead.
All the physics books even at University level  have have it wrong.
Don't believe me.  Believe MIT
https://www.bing.com/videos/search?q=kirchoff+is+for+the+birds&view=detail&mid=943946C8F2CCD60A2132943946C8F2CCD60A2132&FORM=VIRE
