0 Members and 50 Guests are viewing this topic.
kolbacict
Can you get an archive of these magazines there? And why did it cease to exist many years ago?
WhatIsIt
You are right!
As you said I have social issue problem which you don't, so, dont be angry (anger is not social issue behaviour), I wish you well.!
And I am not your "Dear" , please, we are not that close.!
Cheers!
r2fpl
By a strange coincidence, the production of neutrons is by HV and Ion. What is the neutron bombardment used for? to change the atomic structure to radioactive. It is really strange that there are so many similarities. Maybe it's too far away from the way the kapa device works, but you have to look deeper.
If you think that kapa put there material like in a patent or similar, the rest of the device is for stimulating the material to work. Could he know about it? he could not have invented it but only built it based on some materials he got or took.
Moderator  addition:
https://www.glossary.oilfield.slb.com/Terms/n/neutron_generator.aspx
QuoteA device for producing high-energy neutrons by using a charged particle accelerator. Neutron generators are used in various pulsed neutron devices and some neutron porosity measurements. In a typical device, deuterium (2D) and tritium (3T) ions are accelerated towards a target also containing the same isotopes. When 2D and 3T collide, they react to produce a neutron with an energy of about 14.1 MeV. The first neutron generators were built in the late 1950s and soon led to the first pulsed neutron capture log.
http://www.nsd-fusion.com/Technology/How%20to%20use%20Neutrons/
stivep
Part 1:
bibliography
http://www.marychin.org/shows/msc/Chapter1.pdf
https://kb.osu.edu/bitstream/handle/1811/3147/v41n03_131.pdf?sequence=1
http://aei.pitt.edu/91361/1/3895.pdf
https://www.sciencedirect.com/science/article/pii/S0168900218312208
QuoteThe parameters that control the production of neutrons are the working pressure
of the fuel gas, applied voltage, measured current and cathode geometries.
QuoteThe neutrons emitted from the source are confirmed using neutron monitor, bubble dosimeters, nuclear track detectors, and
He-3 proportional counter. Presently, the device produces neutrons up to the order of
106 n/sec at discharge voltage ranging from -60 kV to -80 kV, and discharge current of 20 mA to 30 mA.
non-accessible  but accessible:
https://nuclear-knowledge.com/neutron_initiators.php
QuoteGun assembly devices stay in a
supercritical state during a relatively long time - a time which is sufficient for a background
neutron to initiate the fission chain reaction.
Internal Neutron Initiation:Polonium-Beryllium (Po-Be) initiatorsTritium/Deuterium InitiatorsExternal Neutron Initiators (ENIs)
Wesley
