0 Members and 47 Guests are viewing this topic.
WhatIsIt
You want us to build that?
Wesley, what are you doing?
You were excellent researcher before, What happened to you?
And don't take this as insult or something.
It is not my intention!
moderator addition:
Thermo Scientific MP 320  https://assets.thermofisher.com/TFS-Assets/CAD/product-images/F72973~p.eps-650.jpg
Lightweight, Portable Neutron Generator
https://www.thermofisher.com/document-connect/document-connect.html?url=https%3A%2F%2Fassets.thermofisher.com%2FTFS-Assets%2FCAD%2FSpecification-Sheets%2FD10497~.pdf&title=TVAgMzIw
stivep
Part 2 bibliography  for transmutation.
Neutron  transmutation.
https://nrl.mit.edu/facilities/ntds
QuoteNTD (Neutron Transmutation) Doping process takes place when undoped (high purity) silicon is irradiated in a thermal neutron flux. The purpose of semiconductor doping is to create free electrons (low resistivity). The thermal neutron is captured by the 30Si atom, which has a 3% abundance in pure Si. Due to the high neutron/proton ratio of 31Si, it will release a beta and, by converting a neutron to a proton, the Si-31 atom transmutes to a P-31 atom.
Nuclear transmutation
https://en.wikipedia.org/wiki/Nuclear_transmutation
QuoteNuclear transmutation is the conversion of one chemical element or an isotope into another chemical element.
QuoteArtificial transmutation may occur in machinery that has enough energy to cause changes in the nuclear structure of the elements. Such machines include particle accelerators and tokamak reactors
however
QuoteRadioactive thorium was converting itself into radium in 1901.
so these processes require little to none outside influence
Whenever you have transmutation  you have energy conversion
( Lithuania Experiment)
Neutron activation:
Quoteis the process in which
neutron radiation induces radioactivity in materials, and occurs
when atomic nuclei capture free neutrons, becoming heavier and
entering excited states.
The excited nucleus often decays immediately by emitting gamma rays,
or particles such as beta particles, alpha particles, fission products,
Think of  energy level that is in MeV's. for single particle.
If it comes  from isotope there   is no need to do anything it is just spontaneous.
homemade fusor (nuclear fusion reactor) - neutron and x-ray radiation, silver activation
https://youtu.be/v9DXecl-OX8?t=55
Neutron Transmutation Database (NeuTran)
https://nrdb.nims.go.jp/index_en.html
Example of transmutation with  Neutron:
A neutron collides with a nitrogen atom, resulting in a transmutation.
https://brainly.com/question/11156764
Understanding  Transmutation
https://www.youtube.com/watch?time_continue=18&v=JD5VEzsUE04 ( not everyone will understand it)
The good thing is that in  practice  these processes  are easy to "observe".
You don't need to view it it is  general information about power generation an  d not in our direction
https://www.youtube.com/watch?time_continue=2555&v=14GwG__3mMQ
Natural Transmutation
funny and easy
https://www.youtube.com/watch?time_continue=344&v=I7WTQD2xYtQ
Transition and transmutation the difference.
https://youtu.be/FFJwX_kHPx4?t=51
Wesley's N gun based on Colman  experiment. ( bombardment)
https://youtu.be/0xXZT7YQDE8?t=514  in English
https://youtu.be/K1f6EBx9GtY?t=488 in Russian.
Harold COLMAN & Ronald GILLESPIE Power Generator
http://rexresearch.com/colman/colman.htm
Wesley
stivep
There is no   safe  way.
But it is  relative  term.
Think  about tank in your car with  gasoline in it.
You know  that you can not smoke when pumping  gasoline.
You know that vapor of gasoline if flammable.
But you drive your car.
So is  with decaying particles / isotopes.
The substance of Colman is not active in decaying form but
-When bombarded with photons of 456MHz in impulse frequency  2-6/s
it does  what it says on the video.
You know that  inverse square law is the key to understand  safety.
http://www.radprocalculator.com/InverseSquare.aspx
This one is  for electromagnetic wave including  gamma.
Just few  cm  from the source the energy level of randomly emitted  photons  and particles is  levels  down.
At few cm more  it becomes non detectable by most modern detectors for  AM 241 or CS137  sources.
http://www.spectrumtechniques.com/products/sources/
You know that collimator is
Quotea device that narrows a beam of particles or waves.
To narrow can mean either to cause the directions of motion
to become more aligned in a specific direction
https://en.wikipedia.org/wiki/Collimator
This  acts  as your safety enclosure
You know  behavior  of alpha beta gamma neutron.
And that is enough  to know to have the same level of confidence  as you have with gasoline tank.
Alpha is  heavy  and   slow.
Beta is faster but it is also particle
Gamma is fast
Neutron is fast ( particle)
When not slowed down Neutron simply  miss the target and is mostly not interacting with it.
To slow it down you need Teflon or other similar plastic.
In this point  of  video  the click you hear is   me  simply  pushing  the button of the microphone
As  fast as I  could ( manually)
That creates  pulses at Tx of  100W   output at 440MHz.
Due to high SWR the max power out was  20W   PEP.
https://youtu.be/0xXZT7YQDE8?t=902
the TX  used was TS2000.  no  antenna  but few  winds of  coil  in  Near Field
3cm from Colman  tube.
The simplest way to have N  generator is source of alpha particles  and   beryllium
https://www.physicsforums.com/threads/a-question-on-beryllium-as-a-neutron-moderator.390193/
QuoteNeutrons are liberated when beryllium nuclei are struck by energetic alpha particles producing the nuclear
reaction 9 4 Be + 4 2 He → 12 6 C + n. where 4 2 He is an alpha particle and 12 6 C is a carbon-12 nucleus.
Beryllium also releases neutrons under bombardment by gamma rays.
https://en.wikipedia.org/wiki/Beryllium
The source of  alpha  home smoke detector  with Am241
Wesley
Legal note:
This information is  for education purposes only.
I don't take responsibility for your action.
kolbacict
QuoteThink  about tank in your car with  gasoline in it.
Why doesn't gasoline in a tank explode in electric gasoline pumps with their sparkling brushes? Even when gasoline runs out, it sucks in air ?
stivep
Quote from: kolbacict on June 02, 2019, 03:32:14 AM
here is  some  answer
https://answers.yahoo.com/question/index?qid=20070605223936AAPpsHs
https://answers.yahoo.com/question/index?qid=20071013225842AAUUjh8&guccounter=1&guce_referrer=aHR0cHM6Ly93d3cuYmluZy5jb20v&guce_referrer_sig=AQAAAD64ABzzzTmp1MtpVraFHjdY9pwmSRaana5uPEqM_DdQTKsWB7Hkp57_0IKlwzVUrto0BqjOhZ8xrFlhbebmC0V6DDdt3jWVKrTq_wtglsZw8DY1ypV8B4CZDig8f5-nvo-vG17V3sq3ucZijgPUjqst_RAvDGPqyKp3S8bpkROd
QuoteGasoline does not conduct electricity.
Only water with minerals in it will conduct. Distilled water won't even conduct.
I wondered the same thing when I first changed a tank pump.  1) DC not AC
2) properly grounded
3) gas requires a mixture of air and fuel with compression and spark to combust.
Wesley
