kolbacict
QuoteNow if you ran out of gas, let the pump run dry and kept it running until just before it burned it self out, then pumped fresh air into the tank at exactly the right time you might get it to explode.
:) :D ;D
Well, I basically thought so.
WhatIsIt
r2fpl
Wesley
When did you see the device operating in the garage of Kapanadze. Did you hear any sound? e.g. noise? squeaking? or something you can describe.
stivep
Yes I did.
Sound of relay- click
Tariel  helper was trying to fool  my attention  (yelling)  , and sound of  battery charger(  booster)  used
to start the device.
So he was  sparking  the two clips  of the two wires   to  create the sound  of  the spark.
Than  in  one point (while using his voice at loud)  he connected the  two electrodes to  the device.
There was characteristic sound  of the relay  from the device.
Wesley
r2fpl
The sound of the relay was continuous? or just on switching? what speed could he have had if he was still working?
Was another sound heard. I mean a squeal of 4-15kHz
I know that you have already thought about all this but try to match the best solution all the time.
I also know that you are currently a supporter of Viziv from Kapanadze and this is also a good explanation but I am looking for a connection with ferrites that also have other properties when they are made of different materials.
I deal with this because I had an interesting test and it brought me closer to the ferrites. I remember Kapa saying that he uses 5-6 ferrites in his first device. I do not know why most of them think that coils are there. We also know that similar effects can be with pure iron so an iron pipe could be there. It all hangs up but I want to say that it is now perhaps an investigation to which he returns after 2 years. You can say that I made a circle.
