stivep
Creating Electret from  spool  of coax wire
Important!!!:
The HV   od  30kV or   less, can not  make spark  from shield to inner wire.
Wesley
stivep
Wesley,
You mentioned 6 types of devices you were able to observe can you quickly name the devices or theories?
I was  working on, or having contact with  number of applications:
1 mechanical from application of existing longitudinal wave using sound
2.mechanical from application of existing longitudinal  wave using vibration
3.electrical based on energy  extraction from lightning by turning part of its energy into decaying standing wave
causing  secondary micro-lightning( avalanche and utilizing one in small size controlled environment)
4. Colman
5.electrostatic based on electron trajectory bend  in vacuum in presence  of steady magnetic  field.( similar to tokomac-
  a toroidal apparatus for producing controlled reactions in hot plasma and having noting  to do with fusion)
6. extraction of electrical  energy from Schumann Waveguide / Kapanadze concept
7 magnetic  Ted Annis
8.Magnetic/Mechanical  Extraction and conversion of energy into electrical energy from magnet losing its magnetic force in time.
9.electrostatic Lithuania Experiment.
There are 3 applications in  particle physics
Wesley
mkjekyll
Thanks Wesley,
Very interesting list.  One could in fact refer to much of nuclear physics as proton electricity, I think this is a better nomenclature for some of what we care about here.
Between the lines there is quite a bit available if one uses the modern technology differently, an MRI for instance.  If one looks closely this is akin to the Coleman and several other devices if used in another mode.  This probably makes some sense to you...
