0 Members and 18 Guests are viewing this topic.
saturnio
Quote from: stivep on June 29, 2019, 09:55:41 PM
I have analyzed   patent from Earth Energy  and
I think that  it will  be  the  best if I make video about it.
There is some interesting material  there.
http://www.freepatentsonline.com/20150102675.pdf At  link shows  that is not secure.
so go here:https://patents.justia.com/assignee/earth-energies-inc
but that doesn't give you any good
the best is direct here:
https://patents.google.com/patent/US9564268B2/en
Wesley
Wesley, one thing that I find quite interesting is the grounding. As we know, in some Kapanadze videos there is an special grounding as attached picture shows.
From patent:
"In the resonant mode, the impedance of the power receiver 10 is reduced to near zero thus inducing ground currents to flow into the power receiver 10 where the ground currents are converted to useful form"....    (where "power receiver" is the "ground system", that as I know  it is not a simple thing)
"applying a high voltage electrical impulse to the resonant circuit to induce current flow from the ground terminal through the resonant circuit,"
groot
Great point saturnio and that's  why i have mentioned expensive grounding that killed Teslas tower.
From Kapanadze we learn that it might be smaller and cheaper but this might limit output of device.
Vizin provide patents for surface probes.
1 Tesla tower with ground connection and thats what they build in Texas .
2 Probe with 2 terminals aka spheres . This seems to not need any ground connection at least at transmitter end , im not sure about receiver.
groot
Dear Forum
This might be unrelated to topic ( At this point).
Its been discussed in a past but im still having problems with explanation .
Do to lack of input im unable to get some satisfying results.
https://youtu.be/KLAPRNWuAn4 is a video where Wesley is doing so called dielectric excitation .
All the posts about Vizin  got me little confused and i think i have mistaken this technology with what Wesley did in his video.
What i have now is flyback with two primaries and schematic of phase shifter circuit .
Once more this is not vizin or kapanadze. Not yet . I need to see this first before i can move forward.
Vizin is using phase shift (time delay) to compensate for wave tilt so they can get physical wave at precise angle (brewster angle LoL).
Pastuhkov claims wave form creation when two electromagnetic fields collide at 90 degree time delay .
Is it voltage and current delayed or just one?
His small black box cant be tesla coil and patent does not specify that it must be air core transformer. Thats why ill try with flyback.
Have any of you build it and got positive results ?
Am i going in the right direction?
My flyback has a diode so im planning on using other end to make connection with my sphere antenna and see what happens.
People claim Vizin build based on Nikola Tesla work. I have never came across anything about surface wave, em wave polarization , time delay of a wave
while reading about Tesla or his work. They all claim he used EM wave ( Radio wave ) for transfer of energy, but all his patents state otherwise .
Then you can read in his colorado springs notes that he used non radiating wave .
Scottish physicist Sir David Brewster (1781–1868)
Brewster, David (1815). "On the laws which regulate the polarisation of light by reflexion from transparent bodies". Philosophical Transactions of the Royal Society of London.
This guy did his research  years before Tesla so Tesla must know this and came up with idea of using this polarization not only for light waves but for EM too.
So why all  publications talk about ground currents (NORTON) and non of them mention Zenneck surface wave.
Sommerfeld, Arnold, "Uber die Ausbreitung der Wellen in der Drahtlosen Telegraphie" (Tr. The Propagation of Waves in Wireless Telegraphy) 1909
Zenneck, Jonathan, "Über die Fortpflanzung ebener elektromagnetischer Wellen längs einer ebenen Leiterfläche und ihre Beziehung zur drahtlosen Telegraphie" (Tr. "About the propagation of electromagnetic plane waves along a conductor plane and their relationship to wireless telegraphy") 1907
At Colorado Springs, in May 1899, Tesla, several of his assistants, and a local contractor commenced the construction of Tesla's laboratory shortly after arriving in Colorado Springs, Colorado
That means Tesla did it a decade before first theoretical paper has been published. Where we can find information related to this research. Is it suppressed, lost , or it never happen.
How Vizin guys came up with this? they must be very smart.
Still there is one more question:
Now we know he used Zenneck surface wave and Interface was and still is located between earth and air underneath our feet .
His first patent talked about and experimentally proved possibility of wireless energy transfer via upper strata of earths atmosphere.
What if Wesley is looking at wrong interface. Air earth interface works fine for Vizin, but all static charges are up in the air.
Its only different approach to a problem of extracting free energy that has its source at our SUN.
Maybe this is why Vizin is transferring electrical energy and not tapping in to  unlimited source of energy.
Going back to my questions about dielectric and Wesleys experiment .
I would really  appreciate Your input, Is flyback any good or its just another dead end im running in to.
Any suggestions how test my flyback using signal generator and driving 2 transistors 90degree phase delay  ? Im thinking about flyback driver circuit because its running at resonant frequency,
and phase shifter circuit to feed 90degree input for second transistor.  Coax is good time delay but at high frequency and will not work for my
flyback.
https://www.youtube.com/watch?v=FHXZ9C914S0 Phase shift circuit im considering at the moment.
Thank You
stivep
-video editing
-what computer is right for the job
-what is configuration of video editing computer
- Davinci Resolve 16 video/ film editing software and colorist software
-difference between video camera and film camera-difference between graded and non graded  files by comparison of V-log RAW vs V-log RAW graded
Davinci Resolve is for free Hollywood editing software for both video and film.Studio version cost $300
https://youtu.be/xAXXaNJzwjE
Wesley
stivep
Links to remember for  future  study:
5.3.3 - The resistance/impedance relationship
https://www.tlc-direct.co.uk/Book/5.3.3.htm
Unveiling the topological nature of electromagnetic surface waves
https://physicsworld.com/a/unveiling-the-topological-nature-of-electromagnetic-surface-waves/
A New Approximate Method for Lightning-Radiated ELF/VLF Ground Wave Propagation over Intermediate Ranges
https://www.hindawi.com/journals/ijap/2018/9353294/
15-000-Volts-30mA-Neon-Transformer
https://www.partsforsigns.com/allanson-101530bpx120r-uni-serve-neon-transformer-15000v-30ma/?msclkid=54a2e56dcca51792d911b8779b3f8b34
https://www.ebay.com/itm/Allanson-1530BPX120-15-000-Volts-30mA-Neon-Transformer-at-120Volts/264242723514?epid=15122339
Method and Apparatus for Extracting and Conveying Electrical Energy From the Earth's Ionosphere Cavity
https://patents.google.com/patent/US20150102676A1/en
Wave Impedance and Phase
https://em.geosci.xyz/content/maxwell1_fundamentals/harmonic_planewaves_homogeneous/impedancephase.html
http://www.hyiq.org/. Take it with grain of salt
http://www.hyiq.org/Updates/Update?Name=Update%2014-04-06
Solid state electric generator
https://patents.google.com/patent/US7830065B2/en
Polarization density
https://en.wikipedia.org/wiki/Polarization_density
White Paper: What Actually Creates The 90 Degree Coupler Phase Shift?
https://www.rfglobalnet.com/doc/what-actually-creates-the-90-degree-coupler-p-0001
Method for transmitting electromagnetic energy and device for implementing same
https://patents.google.com/patent/WO2013191576A1/en
Andrey Pastukhov  and Wesley   you must see it
https://m.youtube.com/watch?v=KLAPRNWuAn4
Turnstile antenna
https://en.wikipedia.org/wiki/Turnstile_antenna
ferromagnetic  materials ( top of  page)
https://books.google.com/books?id=wyiFxKP2OnQC&pg=PA157&lpg=PA157&dq
=deterioration+ofsqare+hysteresis+magnetic+material&source=bl&ots=672PKzp-
Rc&sig=LOCLH6pEr_16heZn9tpy2jg7bos&hl=en&sa=X&ved=0ahUKEwipm5juhZjfAhWR
m1kKHU7CBwwQ6AEIKjAM#v=onepage&q=deterioration%20ofsqare%20hysteresis%20magnetic
%20material&f=false
All of the links  have logical  consequences
Wesley
