stivep
Quote from: groot on June 30, 2019, 04:18:20 PM
.. we know he used Zenneck surface wave and Interface was and still is located between earth and air underneath our feet .
His first patent talked about and experimentally proved possibility of wireless energy transfer via upper strata of earths atmosphere.
What if Wesley is looking at wrong interface. Air earth interface works fine for Viziv, but all static charges are up in the air.
Its only different approach to a problem of extracting free energy that has its source at our SUN.
Maybe this is why Vizin is transferring electrical energy and not tapping in to  unlimited source of energy.
No I'm  not looking at  wrong  interface  .
but instead   I'm looking  only at one side of  Schumann Waveguide   that is  The Earth  surface
with  air  on the  top of it.
It just happened that such  structure  is  an interface for TEM  that when properly polarized  works  in  TM mode   and can
in   result be seen  in  that interface  an  be named as surface wave  that was  recognized as   Zenneck wave.
So if you take  any waveguide it has
-shape (length/ width)
The  special  form of guiding is provided  in the  interface.
But in general:
- waveguides have walls .Schumann waveguide  walls are ionosphere and earth.
  And earth is at the same  time a part of interface Air/ Earth
-  so interfaces  in  our case are  two different mediums placed together FACE TO  FACE
having different dielectric properties such as air and  earth
where:
-Air is non-conductive  medium
-Earth is   conductive but lossy medium
To have working interface  it is mandatory  to  have  one of  the  mediums to be conductive.
That expressions applies mostly  only  to  our  case  of J  Corum/ Zenneck/ Summerfield /Viziv/ Texzon/..
Going back to my questions about dielectric and Wesleys experiment .
I would really  appreciate Your input, Is flyback any good or its just another dead end im running in to.
Any suggestions how test my flyback using signal generator and driving 2 transistors 90degree phase delay  ?
Im thinking about flyback driver circuit because its running at resonant frequency,
and phase shifter circuit to feed 90degree input for second transistor.
Coax is good time delay but at high frequency and will not work for my
flyback.
https://www.youtube.com/watch?v=FHXZ9C914S0 Phase shift circuit im considering at the moment.
Thank You
Any  transformer  can be driven  at its  own resonant frequency.
that includes
-transformers with ferrite core
-air transformers as Tesla coil.
-any two or more coils at any shape and number of winds   coupled in Near Field.
-any "neon"HV   transformers
Wesley
stivep
SURFACE WAVES
AND THE'CRUCIAL PROPAGATION EXPERIMENT
by K.L. Corum, Brigadier General (Ret.) M.W. Miller, Ph.D,and J.F. Corum, Ph.D.Texzon Technologies, LLC
https://s3.amazonaws.com/texzon/TexzonTechnologies+Paper+Download/TEXZON_Baylor_Corum_2016.pdf
In 1908 Jonathan Zenneck  formulated  his mathematical  explanation supporting  existence of surface waves known as Zenneck Wave.
Tesla must know  about it   but since  he  was cut with finances by JP  Morgan in 1897  ,he concentrated on  building his
Wardenclyffe Tower (1901–1917)
In his  time K. Norton  discovered   radiative ground wave  known as the Norton surface wave.
QuoteGround wave refers to the propagation of radio waves parallel to and adjacent
to the surface of the Earth, following the curvature of the Earth.
This radiative ground wave is known as the Norton surface wave
https://en.wikipedia.org/wiki/Surface_wave
https://www.pitt.edu/~jdnorton/teaching/HPS_0410/chapters/quantum_theory_waves/index.html
As oppose to :
Radiative Norton wave  the  Zenneck wave is:
non-radiative
1979 Hill and Wait analytically found an aperture distribution that excites a pure Zenneck surface  wave  with no  radiation  field.
Note: no radiation  field means, it does not radiate in  air  above the earth  in Far Field
It is the effect of    cylindrical wave in Near Field around cylindrical   antenna  ( Tesla  Tower)and its electrical field is
Quoteevanescent (exponentially decreasing) in the +z-direction.
From that time but based on today's knowledge we call it :
Quoteno Hertzian radiation or Norton ground-wave radiation whatsoever
I need to mention here  that Marconi was trying to send electrical energy  using earth in Bolinas California in 1913.
https://youtu.be/r3XVRd-G56k?t=655
Please take  this video  as  asserting but not explaining.
However in:
https://youtu.be/r3XVRd-G56k?t=1002
Marconi schematic
Marconi was screwed  by newly formed  RCA "
in 1921 -. business in Bolinas was closed  due to RCA action.
Marconi started to sue  US government of illegal use of his patent during 1WW.
After death   of Tesla,  US Government revoked  patent  rights  of  Marconi  and gave it to Tesla who was dead in  this  time.
US was freed  from  paying any money  to Marconi.
Wesley
stivep
links that likely will  be used  in this set of posts.
1.       Transmission Line Modes
https://gradestack.com/Electromagnetic-Field/Transmission-Lines/Transmission-Line-Modes/19383-3931-38714-study-wtw
2.       Model FIM-71 portable, laboratory quality Field Strength Meter
https://testequipment.center/Product_Documents/Potomac-Instruments-FIM-71-Specifications-32D80.pdf
3.        Basic Tesla's Experiments (Part 7) -  Standing Wave, Node, Reflection
https://www.youtube.com/watch?v=nkMndCsNRQU&t=1s
4.        Milford TX Tesla Tower Close Up
https://www.youtube.com/watch?v=WJtPNR4T6FI
5.       1 - Class 12 - Physics - Wave Optics - Wave front and Huygens's principle
https://www.youtube.com/watch?v=sk_2OOWjjes
6.      2_2 Electric Field Superpostion
https://www.youtube.com/watch?v=FMOGXwR4HAs
7.     Normal (geometry)
https://en.wikipedia.org/wiki/Normal_(geometry)
8.     Wavefront
https://en.wikipedia.org/wiki/Wavefront
9.     3.6 Plane Wave Polarization
https://www.youtube.com/watch?v=84AcKIcF7VY&t=50s
10.  open and shorted slow wave  helical resonators
no link  yet
11.   Re: slow-wave helical resonator
https://www.pupman.com/listarchives/2002/August/msg00303.html
12.   Green's functions
https://www.youtube.com/watch?v=-riPW1yt_fA
13.   point of charge / line of charge......point source/ line source
no link  yet
Wesley
stivep
