0 Members and 161 Guests are viewing this topic.
Void
Quote from: stivep on July 20, 2018, 05:58:49 PM
Please look here
https://youtu.be/atlnVNy0IDE?t=629
and than
look  at the picture
Wesley
Hi Wesley. I have spent many many hours running all kinds of experiments along these lines
over quite a few years now, and from what I saw from the Old Scientist's experiments shown,
I did not see anything that I would say gave an indication of anything very unusual going on.
His exact experimental setup was not clear to me however, so without knowing his exact
setup I can't really comment further on it.
I was not suggesting that having two separate earth grounds is not a viable way to go when
trying to achieve COP > 1, as Frank Prentice used at least two separate earth grounds and
claimed to have measured a COP of around 6.  I was just saying I did not see indications
that Kapanadze uses more than one earth ground connection. I am attaching a couple of drawings
from Kapandze's patent applications. They seem to depict only one single earth ground connection,
which is consistent with what we have seen in Kapanadze's video demos over the years.
esaya
what you see in the patents you can't see it on the demo video,
what you see in the video demo you can't see it in the patents.
the first video (tin can) and first the patent is the simplest, i think Ruslan has been succesfully conecting the dot.Ruslan last  video (16 watt) look very similar to Kapanadze tin can video.
similar material, inverter 12 v dc to 220v ac,power suply 220v ac to 12 v dc ,coil wound look similar.
Ruslan : DO NOT PURSUE THE POWER (get the 220v ac from inverter?),TESLA CURRENT (with controlled Tesla),GROUND FROM EARTH
So guys! I'll tell you all easier. If you want something to collect, do not pursue the " POWER ". So the pumping is simple without resonance. Tupa is a magnetic alternating field! Next ... Position the coils so that one coil with its own field does not stack with the other. That is, the shift must be done. Otherwise OLED will interfere! Now we remember Tesla and when we bring to her a sheet connected through a light bulb to the ground ... What do we observe? The answer is correct! Light bulb shine :) This current you need! Now, by inducing this all on your reel, the end of which is grounded ... You make the magnetic field longitudinal (pushing) and transverse, creating a flow of motion! I told you that the generator of BTG works like a normal generator. Hence Tesla pushes the current, or in other words, pushes or carries the magnetic field away from the pump by a longitudinal field. There is no OEDF! Nothing hinders and there is no resistance either! How are we in the classics? Currents on the sides of the coil?! Here! Boca then do not match :)
And now make a controlled Tesla! That is, interrupt the pushing of the current at a frequency below the pump. This is the current flow! Well guess what, finally, damn ....
How much can you say that?
Hoppy
Wesley,
Like the green box device, the Aqua 2 device appears to power a heavy load with a single ground wire so how does the dual physical ground wire theory add up to what we see in any of Kapanadze's videos?
If these devices are genuine, then the principle is very likely very simple as Kapanadze claims. The biggest clue in my opinion is that Kapanadze avoids running these devices in stormy weather, which suggests that there is a concealled connection to an aeriel wire, assuming the devices are not faked. I'm trying hard to join the dots.
AlienGrey
Quote from: Hoppy on July 21, 2018, 04:05:21 AM
Wesley,
Hoppy the answer to your question is easy ! answer you haven't done your home work with watching the old scientist video's !
the single earth is a mono polar Tesla coil, Also do you remember some 2 years ago Nelson talking about the very same coil
wasting energy? you can also make a coil with out the harmonics. My advice to you is watch them while you can they are saying (catch us if you can) sounds like a pop group from the 60s  ;D
P S two earths or none is a bipolar! reminds me of my psychology OU coarse I did,  :o You say he doesn't run the device in a thunderstorm  ;D :D a very verrrrrry wise man, surely you can work that out for your self!  ;D ;D ;D
AlienGrey
Quote from: Hoppy on July 21, 2018, 05:28:58 AM
Hi Alien,
I've watched most of his videos but cannot recall where he has demonstrated operation without a conventional power supply in a self-running mode. You continually write as if you have the 'knowledge' and proven the operating principle of the Kapanadze devices, by self-running your own device(s). Can you show any evidence of your achievement? As you are well aware there are many that can talk the talk.... ;)
Hoppy no I can't and I don't have the test equipment to develop such a device, did you notice the HF SG the Ols Sci was using
I only have a 5 MHZ device to get any where you need a 100mhz device with PW  impulse drive.
Where are you perhaps we could pull resources ?  you talk about the green box that device would be one of the easiest to play with and perhaps get going to prove one way or the other.
On the other hand tin mans device does prove the point quite well.
Ove course you could wind a Tesla coil 1Mtr long and work out the wire length for 100khz and tune it to that frequency to prove the point and then use a ferrox core transformer to collect it all. but the trick is done around the Tesla coil.
AG
