r2fpl
The film has two different grounding locations: https://www.youtube.com/watch?v=T4xUe62nWtA
1.water pipe
2.car radiator
the difference in these places gives a hint about why grounding is needed. We have two options:
a) energy goes to earth
b) energy comes from the earth
Both of these points are possible but what do we know about the differences?
(a) clamp meter = 25A in place to earth so the circuit would have to be closed to earth! but it is not so unless Kapnadze has deceived us.
(b) is 25A justified? Yes of course. The question remains as possible. Possible ! and the circuit does not have to be closed.
This is the most important thing that everyone does not understand.
Does it meet all the dependencies we know from the accounts of witnesses, Kapanadze stories, patent, rules looking at movies, device power and Kapanadze's statement that the amount of energy is practically any in quantity - YES
... still this is only my point of view.
Wesley - I'm sorry if I interrupt your thread?
groot
Hello.
Im trying to build 1.8Mhz transmitter. I try to stick to slayer exciter circuit.
Question is :
I have small coil 0.5 inch diameter and approximately 1000 turns but i cant get it to work at all.
Many turns primary or just a few still not getting any hv.
Is diameter too small?
Next question is :
If i use bigger coil that works fine and adjust its wire length for standing wave, resonance at 492 khz 500 feet wire length
how it will change the distance I need to keep between Tx and Rx?
Is that frequency dependent ? I am not going to use more than 80W. Top load is a toroid  30 inch diameter ( still need to calculate that) .
Mast is pvc and i should be able to get it up 6 to 18 feet.
Thx
groot
Im sorry for oversized Photo.
Wesley did you use 1/4 wavelength resonator?
What about 3/4 of a wavelength ?
1.8 Mhz Is pretty short wave. I just try to avoid hard tunning, expensive mmc and all the interference coming with SGTC.
Thx
stivep
yes groot but  since it is a lot of coil to wind I used approach of Tariel Kapanadze
CW CCW  to  make coil  electrically smaller.
However this is not needed .
Remember HV TESLA COIL  MUST BE   in  VERTICAL!!! position
Effect  of energy    transfer between two Tesla coils at some distance is seen and recorded.
In Near Field   it behaves  as
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg537509/#msg537509
but
for experimenter operating  with  limited  tools, make sure that  you really extracting energy from  interface at best  there is need to be  63f =19m or more , from the Tesla coil acting as Tx
Fluency in this first step is needed to  go to second  part of  it and that is  extracting energy from Schumann Waveguide
https://patents.google.com/patent/US10103452B2/en?oq=Patent+number:+10103452++
stivep
The configuration from above picture is also  not needed.
However it is closer to SR193 , Akula, Ruslan (yoke)
The  advice  is not to complicate things.
All of that WORKS!!!
there is not better or worse  solution
The only advantage  comparing to classical   Tesla coil is SIZE!!
Konfiguracja   jak na rysunku u  gory  nie wymagana.
Nie komplikowac sobie zycia.
Wszystkie  podane  konfuguracje  pracuja tak samo roznica jest tylko  w  rozmiarach
Cewka wys napiecia musi  byc pionowa!!
Wesley
