0 Members and 18 Guests are viewing this topic.
clearuniverse
Another very actual knowledge about ULF/ELF science and Schumann resonance.
Language: English and Polish.
https://pub.igf.edu.pl/files/Pdf/Pubs/132.pdf
Nowadays You can't discover anything new without expensive test equipment and big knowledge about modern physics.
BR,
Clearuniverse
stivep
Quote from: clearuniverse on August 27, 2019, 09:11:45 AM
QuoteP polarization is commonly referred to as transverse-magnetic (TM), and has also been termed
pi-polarized or tangential plane polarized. S polarization is also called transverse-electric (TE),
as well as sigma-polarized or sagittal plane polarized.
https://en.wikipedia.org/wiki/Polarization_(waves)
Serdecznie dziekuje
Wesley
Quote from: stivep on August 25, 2019, 11:03:15 AM
so where  is  the "trick" of activation?
How  that can be done?
There are few ways  to go around.
One  of them is to take look at third order of  Schumann resonances
and realize that  60Hz is 3 times of that.
I think I said  to  much now :)
But I'm trying to  attract the  most  involved  brains  in  this forum
Note: that what makes upset some of opportunists  here
Everything  published here prevents anyone  from
any form of  patent  protection  in the future.
Everything  that I decided  to  publish  is  in public domain  and it is  the  information  with one purpose in mind .
Wesley
60 Hz /3 = 20 Hz. + " it must be vertical" hypo-/thesis  ! ?
Counter-design and concept, horizontal:
http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=FR&ENGINE=google&FORMAT=docdb&KIND=A&LOCALE=en_EP&NUMBER=667647&OPS=ops.epo.org/3.2&SRCLANG=fr&TRGLANG=en
Inducing flux ( centrifugal)  / induced flux ( centipetal)
For some unknown :
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=Adolf+zielinski&IN=&CPC=&IC=
stivep
Ok ale Wesley powiedz nam skad sie bierze ta ekstra energia? jonosfera jakos wzmacnia te fale ktorymi strzelamy miedzy jonosfera a ziemia? jesli tak to dlaczego?
Ok but Wesley tell us from where the extra energy is coming from? is the ionosphere amplifying the waves we are shooting between ionosphere and the earth ? if so then why?
There  is no extra energy and  never was  any extra energy.
If  you take  your Tx and   connect your coaxial cable ( 50 Ohm transmission  line)  open or shorted at the end  you  have impedance mismatch.
Standing wave will be bouncing back and forth.
However if you now  connect 20 Ohm resistor or antenna  to the   free end  of that coaxial cable  than   part of this energy  will be dissipated  to this load.
That Standing  wave will be lesser of SWR mismatch    5:1, 3:1,  2:1 and so on...
The same is with standing wave    in Schumann   waveguide .
Part of that  energy can sink into  interface earth/air in  the  right conditions when wave  tilt angle and polarization is right.
All you  need  next is  to take device of Tariel  Kapanadze  = Tesla coil
and  tune  it to that:
-Frequency  ,
-polarization
-tilt angle.
-impedance
Wesley
