onepower
Groot
QuoteSince everyone is eager to answer questions i have one more.  ;D
Tesla coil is often described as antenna. Its very poor antenna that is radiating poorly.
Nikola Tesla designed it as a device that sends power over large distances. ( im skipping word wireless on purpose)
Hey Groot, the reason so few have been able to make this work is because they have not read Tesla's work or listened to what he was saying. People often describe it as an antenna however in order to produce the desired effects we must do the opposite of what everyone else does and turn the antenna upside down.
Tesla said the HV secondary coil and the top load must be perfectly insulated to prevent all corona effects, radiation and losses. Nobody listens and they use a leaky top load which will radiate energy and negate the proper effects. Everyone has it backwards and upside down thus it is no wonder they cannot make anything work. The process was to store a great deal of energy in the insulated coil and top load with no losses or radiation then drive it into the ground plane in a single impulse with no return. This produced a HV surface conduction wave which travels along the ground much like a solition wave. What Tesla was trying to do was reproduce the effects similar to a lightning strike to ground. He even said this was where he initially got the idea... lightning. Think about that, lightning is obviously not an antenna and it does not produce EM waves therefore it's not the same thing.
Now one could say the wave like disturbance must dissipate and it does to some extent however we should understand this is not a Hertz or alternating EM wave this is a DC conduction wave. From Tesla's work with extremely HV he understood that even the best insulators act like conductors if the voltage is high enough. From this he deducted and proved through experiment that voltage (a difference in potential) can be replaced with a singular wave of very high potential which does not alternate in potential like an EM wave.
Understand, an ocean wave "alternates" like an EM wave above and below the average or mean height bound to every other wave however a solition wave travels as a singular disturbance not bound to any other waves. Obviously, if it is not bound to any other EM waves then it can act independent of them and is not bound to act like them. As it turns out all one has to do is not do the same thing as everyone else does over and over and over... do something different. I mean it's so obvious and self-evident it boggles the mind doesn't it?.
Why anyone would keep doing the same thing over and over when they know it doesn't work is apparently beyond my understanding. So there you have it, do something different, do the opposite and you will be well on your way. People just aren't all that smart but mother nature is a genius with billions of years of evolution to back her up, think about that.
groot
Quote from: onepower on October 23, 2019, 06:46:38 PM
Groot
Hi onepower. Thank you for your reply its much appreciated. I totally agree with you. Everyone should educate themselves and follow intuition.
Thank you for sharing  your opinion ill look in to it.
One must be open minded but should restrain from foolish coping some diagrams not knowing how that device work.
Thx
onepower
Groot
QuoteHi onepower. Thank you for your reply its much appreciated. I totally agree with you. Everyone should educate themselves and follow intuition.
No problem, I agree and it's strange how all these patents we see are almost never as they seem. The most important parts relating to a working principal and the process are always missing. The trick I have found is to not get too hung up on what we think we see or hearsay and look at any given technology objectively and conceptually.
Absolutely the biggest mistake I see many people making is assuming because something looks similar to what we have seen in the past it must act or work similar which is not always the case. My line of reasoning is that if I was actually intelligent all of the answers should come naturally and flow like water however this is not the case. At which point it occurred to me that it was never the capacity to retain a bulk knowledge of science or technology which relates to other people but to try to do our own thing as an individual. Conjure up a new concept, start experimenting and see where it takes us.
ramset
Thanks Grandma
kolbacict
QuoteConjure up a new concept, start experimenting and see where it takes us.
totally agree. There are a lot of lies on the Internet. Do not trust anyone and do not listen to anyone. Do it yourself. I try.
