0 Members and 27 Guests are viewing this topic.
groot
Hello
I came across this website recently
https://www.inverse.com/article/45546-nikola-tesla-conspiracy-theory
Thx to professor Corum we know that this is possible and Tesla was right all along.
Wesley you know much more and much better about this project so answer this.
Tesla was digging deep in to rock at Colorado location to create a good ground connection. He even run water 24/7 to keep resistance low.
Corum explains in his patents that there must be incident present at Brewster angle, and physics  teach us about refractive index and two mediums and that wave must originate in certain medium. Antenna ground mirror reflection tells us how to do it. It takes a lot of work to accomplish.
So now tell me why they didnt build it at sea, under water ? according to Tesla and Corum this can be received anywhere in the world including sea and ocean, and if you can receive it there im certain you can Transmit as well.
By any chance does anyone know where was located a power plant that supplied Wardenclyffe Tower ?
Thx
kolbacict
Why does the asymmetric inductance with a permanent magnet not create a constant component in the AC circuit?By analogy with a semiconductor diode.because there is an asymmetry of the forward and reverse current.
stivep
I'm not sure what is that you asking  for.
Can you be more specific?
Are you asking  about  The asymmetry between forward and reverse conduction as the basis for rectification ?
http://tuttle.merc.iastate.edu/ee201/topics/diodes/diodes.pdf
One of examples of asymmetry and related to it energy is here:
https://arxiv.org/ftp/arxiv/papers/1801/1801.05229.pdf
Wesley
kolbacict
Well, something like that. A semiconductor diode rectifies the voltage, and a nonlinear inductance should rectify the current.But there was no constant voltage on the load.
stivep
first lets clarify  what is :
The behavior of an inductor for which the voltage drop across the inductor
is not proportional to the rate of change of current, such as when the inductor
has a core of magnetic material in which magnetic induction is not proportional to magnetic field strength.https://encyclopedia2.thefreedictionary.com/nonlinear+inductance
Example of Variable Inductor  that in this case  has the inductance as a function of its current
:http://www.beigebag.com/case_nonlinear_ind.htm
Conclusions:A lossless, nonlinear inductor model has been created.
This model is suitable for use in strongly nonlinear applications such as those using square
loop cores, or by curve fitting, to create a somewhat 'softer' models more nearly
approaching the performance low loss devices operated over a large range of flux (current) where a lossless, linear, straight line, unsaturating device model does not
fully result in good approximations of the actual circuit behavior.
but.. that what is puzzling me is:
-your wording   pointing about rectification
-addition of  permanent  magnets
can you explain it more?
Wesley
