0 Members and 18 Guests are viewing this topic.
ramset
Ansis,quote
Good morning!
I discover interesting thing relaited with old LiPo batteries!
Batteries about 10-15 years old, when they are lose capacity, is turning in to SuperCapacitors with capability to recharge themself. Of course energy density after "recharging" period of 12-20 houres drops down, but it is amayzing. My setup is made from 3 old+1 old, but not compleatly dead LiPo 18650.
I watch this YT video about quantum battery.
Very interesting.
https://youtu.be/7fM4e0cx5zU
Thats all for now.
Yes, for better results 3 batteries must be dry and we must go and destroy elements by charging them with 25Hz DC impulses and Voltage must be around 9Volts and Voltage on the batteries in that moment must be 5V DC.
Good luck!end quote
maybe start a topic ?
I will drop in Plengo topic [great open source experimenter here with dry "energy harvesters"
Chet K link here https://overunity.com/15035/crystal-cell-research-for-experimenter/msg541798/#msg541798
more info PLEASE ?
Thanks Grandma
Ansis
OK.
I just observed possibility of "second life" for old stuff with interesting properties.
I just give the idea, not to throw away but use for projects? or whatever.
ramset
Ansis
yes some will say "not safe" or other comments
if you could give more detail ?[new topic maybe ?
to understand recycling these or this "back to life" ??would be nice to understand
and a great open source project
thx Chet K even start new topic in Wesley section?circuit timing etc etc seems simple at a glance
Thanks Grandma
magnetstoo
I forgot to include data taken from the output of the core,after the bridge diode, to the 125w bulb...#6 is a Log of the spectrum showing the wide spread of frequencies and the falling off around 2.5 MHz -of which I found also an interesting region.Core has a natural rez about 1.14 MHz.Also a picture of the 125w bulb--(grow lamp for plants) it has a blueish coating.The picture is close to its actual brightness,perhaps a bit brighter.
Raycathode
Quote from: sm0ky2 on January 08, 2020, 09:35:36 AM
Energy is in all mass.
Mass causes gravity, which is a separate quantity of energy.
a potential energy based on the locations of the masses.
Therefore, space itself contains energy.
(mass and 3-d distance)
Gravity is the potential energy of 2 masses to become 1 mass.
(which increases the total energy of the mass by the additional mass)
Therefore, mass in the presence of other mass creates energy, relating it
in the form of kinetic energy, as it combines its energy with that of the other mass.
Total final energy of the mass system is the same as before they approached each other.
However, the change in kinetic and potential energy was created AND transferred elsewhere
as they were approaching.
Let's take this a bit further and consider galactic masses (countable) infinite distance apart.
There is (countablly){countability only has one l} infinite kinetic energy between these galaxies.
Infinite!!!
Defined only by the special dimensions and the magnitude of the mass.
So by increasing the energy of a mass (by adding more mass) creates energy from the vacuum.
If the universe is truly "expanding", then the potential energy of the universe is infinitely increasing.
Would anyone be prepared to challenge this idea as to what gravity actually  is and how it really works
I know the above idea is outdated and it is more about electricity and vibration and the way electrons and protons are bound and pull and bind together in order to lessen their potential charge and are thus
strongly attracted to the center that being the center of the earth where there charge wóúld be minimal.
and gravity as far as mass and weight is just an effect of the elusion this assumption is based on.
Raymondo
