0 Members and 65 Guests are viewing this topic.
Raycathode
Without getting too involved here would not harmonics fit into this Categorie of the drawn-out elastic band.
Raymondo
r2fpl
Quote from: stivep on January 11, 2020, 11:46:09 AM
You welcomed with any  findings  thank you for that.However  you  didn't respond to my questions from above. Can you?
Мы приветствyeм вас с любыми выводами, спасибо вам за это.
Однако вы не ответили на мои вопросы сверху.
Ты можешь....прежде чем вы углубитесь в то,нa чем вы пытаетесь сосредоточить наше вимание??
Простой вопрос :
от  куда энергии берется и как
от  куда Энергия берется до того,и как она попадет на устройство.
Объяснить весь процесс
Wesley
DELAMORTO replied that it was an oscillatory circuit. They call it REKTIVKA, I think you know what it is.
The problem is that no one can get that power out of this circuit. It is only in calculations and measurements before loading. When you do load, the resonance falls and the circuit begins to operate normally.
Until the phases overlap, it looks like kW, that's why some see power here.
DELAMORTO
r2fpl, да именно так, как сказал Капанадзе- никто не мог заставить его работать.
Весли, а по вашему что потребляет 60-100ват  в видео "Банка" ? Это накачка колебательного контура!
kolbacict
https://youtu.be/-PMMK4KHXYU
Have you gotten that Los Alamos radiation meter? Probably Opengheimer worked with this yet. :)
I also want this. ;)
magnetstoo
  I now have a 250 watt, 2.2a, 4.1 ohm IR bulb running on my system.Bad thing is, brightness is only about 1/10 of what the actual output would be if the D.C. input was applied straight to the bulb. Power input is now 48v @ .85a---I received the OPA 549,it works fine but has a 30v limit,so Im using the OPA541 with its 40v limit pushed to 48v.Overall the  core still runs cool but the heat sink on the OPA is getting rather warm.I had to re-adjust for the 250 watt,now the IF is down to about 95 kHz from the previous 190 kHz,and the output at the bulb is now 45kHz from its previous 100kHz.There is one small area where the antennae adjusts,about 1 sq.in, where the bulb lights the brightess. The AM radio still has a clean signal with no static,but no stations can now be heard so I assume its over-riding the 455kHz IF.
