magnetstoo
 Let me add this unusual fact about this---this 250 watt has  the same "color" or " brightness" as the 4watt I tried,the 20 watt, and the 125 watt,....It all appears as if the voltage is constant in all of these,but the amperage is what varies with the load, (that is just an observation) .....Why I cannot fully light a 4 watt / 125 volt bulb puzzles me when I can light, just as easily, this 250 watt bulb....But Im on the case...I have 45 KHz to go.
   This is the first time,as I recall , Ive seen such a frequency drop in my IF stage.Did not appear to drop before,but things changed when I tried the OPA549 and then switched back....I have noticed this drop  in earlier trials with this split core setup,but I was using Neon bulbs as the load in which case the voltage output kept going up,I had 1700v before the 7 watt stereo amp driver gave up (I think the 1700 volts back-flashed)..It was never the same after.
   Im not trying to "ramble", just letting anyone interested  know the data I have accumulated.
magnetstoo
I now have 375w hooked up ---(again, only 10% output / input ratio)---I have included some measurements taken direct from the antennaes ( L-coils ).
    Also ,the ground line I use is about 40 feet of what appears as silver coated, multi-strand, 2/0 wire.It was a little expensive but not the worst in price.
   The system did not drop in frequency adding the extra 125 watt,so I have not reached that limit yet I guess.I also found that with a smaller load the core output can be run off just one leg of the 150 turn cad. coil...Also, the IF stage can be eliminated too but a small load and careful tuning would be needed.
   I hooked up a 120v / 250 watt, 67 ohm heating element and it reached 125 deg F inside 15 minutes with an input of 48volts / .28amp..It will draw twice more amps but will not be as efficient. I can tell by the output on the scope when it resonates or does not. I guess the OPA541 absorbs this extra current, because I cannot find any where else it goes.
kolbacict
endlessoceans
This is a good example of an excess energy machine.  The process of which is defined clearly and has been replicated and exhibited in other patents and applications.
Clear explanation of known principles
No hogwash pseudoscience such as fancy waves and surface energy that Wesley goes no about
https://patents.google.com/patent/US20160049839A1/en?assignee=Arion+Technologia+Brasil-Gestao+De+Ativos+S%2fA
