Ansis
Both Ampermeters in series give identical mesurements.
I don't understand joke.
P.S. If you have good low resistance Ampmeters, everything is correct!
If you have high resistance Ampmeters, you can observ mismatch.
groot
Thank you for your reply Ansis
Why you think im making a joke?
This simple experiment disprove your claim that circuit is "eating up" the current.
If you attach earth grounding will this make more current?
No? But wait what about all the free electrons you introduce to the circuit?
Earth grounding is a part of safety system of a circuit breaker. It gives a current safe path of low resistance so circuit breaker can activate and you dont get electrocuted.
This has nothing to do with free electrons in earth other than  low resistance conduction.
Tesla coil can be grounded. It performs better. Is it free electrons from earth? No its ground plain image that makes tesla coil perform better and not free earth electrons. Tesla coil is nothing more than 1/4 wave antenna. Only difference is that tesla coil radiate poorly compered to radio antenna.
I assume you compare current in a circuit to fluid that os accumulated in enclosed vessel and circuit is a bridge, pipe as you like to empty vessel.
If its so then current should be less then what it is before it enters the load. But is not and you just confirmed that.
This means that current is not a fluid that performs work and is being used up, converted in quantity.
Since your light bulb has specific resistance current can reach only level set by known laws of ohm.
If you use light bulb of lower resistance current will increase.
Does that means your battery can produce more current. ?
No it means current depands on resistance of the path , your bridge between dipole.
So why battery is being drained off current since it does not create current? Current my friend is only the effect of killing the dipole. Dipole does not create current, dipole creates condition of unballance that ambient medium try to fix by ballancing and effect of it is a current in a closed loop. Without closing the loop ambient cant react to presence of a dipole.
More to come if you are interested. No jokes only lessons.
Thank you
Ansis
Your true is only in your Universe!
All Free Energy believers, make they'r own reality!
Dipole is negative and positive wave ballanced in the antena which is constructed for perfect match.
It is radio.
Dipole is AC if you want, every frequency have physical dimentions according with frequency.
Radio physics.
Nothing more.
P.S. I believe in Free electrons of the Earth and that is my crazyness if you want!
Free Energy is hox and I believe in that!
r2fpl
https://www.youtube.com/watch?v=_Ec7ba6vutg
see time 6:40 after all video
However, it doesn't matter because you need potential relative to the earth. I do not know the production method only + or - without costs.
If you find such a method I showed you when the electricity will come from the ground.
Are these your "free electrons" happy?
r2fpl
