Toolofcortex
Delamorto, I suggest you offer individual counseling and videos to private builders who will pay you 5000$.
There is nothing against the law in this.
Your circuit.... You are just LUCKY to be a russian speaker.
You got lucky, is what I think. Might you share the luck with me for a fee?
rakarskiy
Quote from: stivep on January 27, 2020, 06:28:45 PM
I examined Tariel  Kapanadze device  in Tbilisi and  I didn't find fake there.
9 years after my return  from Tbilisi I found explanation  of Kapanadze in Viziv.
But Dr James Corum and his even more  brilliant brother Kenneth Corum  didn't go officially that far.
Your problem my dear Friends is that you are waiting for someone to leak it to you.
You  have it in front of your eyes and likely none of you wants to try it out.
My 3 videos says it all.
https://youtu.be/zE4GjB1cWLQ
https://youtu.be/XOTLfnMOSqQ
https://www.youtube.com/watch?v=yNs2wc8nRJw&feature=youtu.be
Indeed, we can say that you held the Kapanadze device (KAPAGENERATOR) in your hands, you explain how it works, the work done in this area as a researcher is impressive and deserves respect. I assume this is your version of how it might work.
There is one interview with Tariel, where He claims that the closest approach to his principle was made by Andrey Melnichenko (whose last scheme is a reverse-pass Converter with a OU conversion effect). Tariel also has a Converter.  Forward or reverse, the Converter is a DC/DC class. The spark gap is the key for the pulses in the Converter circuit. There is a version that Tariel in Soviet times, in a Research Institute of the USSR, was in charge of the economic part, and concurrently responsible for the Archive. This Institute was engaged in the development of gravitational aircraft. And this effect was discovered by them accidentally or developed for the energy source of such an aircraft device.
I think the formula of the Kapanadze device is simple, the Ohm's law must be triggered In the secondary circuit for the full circuit.  There are several devices that intersect and one of them is the "Tricky zatsarinin transformer", but Sergei Borisovich has it running on alternating current.
Researchers have not yet solved the principle of operation of the tricky transformer and Kapanadze Converter.  Zacarinin, (claiming that the principle of operation of the device can be made in several variants) has filed a patent application. Unfortunately, this patent has not been publicly available since 2008, and more than 10 years have passed.
Probably in the RU 2412520 paper is Zatsarinin transformer knowledge incorporated.
rakarsky,related "Ohms ( and Fourier) law" : Prof. Michal Lipson ,Columbia Engineering
macro-scale versus nano-scale "Nanoscale heat transfer 100 times stronger than previously thought
( all about circuits : April 05,2016 from nature nanotechnology March 07,2016 )
rakarskiy
Quote from: lancaIV on January 28, 2020, 09:21:26 AM
Ohm's law is an empirical physical law that determines the ratio of the electromotive force of a source
(or electric voltage) to the current flowing in a conductor and the resistance of the conductor. Founded by
Georg Ohm in 1826 (published in 1827) and named after Him. By the way, this is not a fundamental law of physics,
but a special case. This is our University physics.
