0 Members and 27 Guests are viewing this topic.
kolbacict
https://www.cryptomuseum.com/df/1100ar/index.htm
Thanks for the interesting site. But it seems to me there were digital indicators. And the performance is desktop, not in the rack.Although it seems that it was in a past life ...
magnetstoo
  Well I do not know what is going on with this device.....it is now running on a minimum... 2 induction coils, 1/2 ferrite core, 1 diode , 2 capacitors and the OPA541,plus heavy grounds...and I have the same output with 1/2 the core missing...It now starts with momentarily touching the dipole ground to the 1/2 core,15 turn winding.....The output of the core is now one wire which goes through a .3 micro-farad capacitor which itself runs cold.The single diode gets warm but can be held in the fingers, yet tries to light 370watts of bulb power.The core also does not appear to be warming up....The OPA541 is running 44.8 volts @ .8 amp @ 85 kHz now and must be somehow powering those bulbs through that small .3uF capacitor---I can feel the heat radiating from the orange filaments.I do have a heavy ground connected to the diode and the OPA541...If the induction coils are moved too far away,the system shuts down and will not restart until the dipole ground is again touched to the core winding.The ground can stay attached or removed--makes no difference.
It does appear though that both capacitors play a significant role in the resonant core.I know the coils do.I adjusted the capacitors,a month ago, for maximum output, and minimum capacitance for the 14 watt bulb I was using.
    Now here, I removed the second half of the core while it was running, I held the second half of the core to the first half and felt the buzzing from them as they tried to connect.I then decided to try just the one half (15 turn half) and it lit the bulbs,I then removed the ground side and the bulbs stayed lit. So I am now down to one wire trying to light 370 watts. Bulbs colour and brightness have not seemed to have changed as when I had all that other attached,but the frequency of the system has went from 65kHz to about 80 kHz.OPA541 can be ran without its fan for cooling but appears to warm up over time------------- ..Note this is an ongoing project and I can only tell you what I have discovered....Schematic is correct as I believe it to be.Nothing hidden.
magnetstoo
I posted a bit too soon it seems because my system no longer uses the small caps,nor does it need a momentary contact--it starts as always by adjusting the bi-fi-coil,of which 1 is only required but 2 gives it a boost.And the bi-fi- hookup lines have been reduced only because it made no difference in output that I notice,so I left those off too.It is much more streamlined for a given output.----The ground line---that has a big influence I now notice...The system will not run with a flat copper cable line to the copper water pipes,I tried...It uses a 40 ft. line, of 2/0 silver coated,multi strand cable ,clamped  to a 3 foot copper pipe hammered into the ground...System appears to run the same without all the extra baggage.System resonance has dropped to about 54 kHz from 65 kHz.Still uses a single diode.System will not start nor run without the 1/2 core attached with its dangling wire.It will run with either the 15 or 150 (cadaceous) coil/core attached,despite the wire to nowhere.The core gives out a stronger field with a larger load..... RWG Research on You-Tube makes similar induction coils if your curious where to find them.Im sure he still makes them.
stivep
