stivep
New developement  about Viziv Technology in response to Mark comment :
https://hackaday.com/2019/11/20/texas-tesla-tower-titillates/#comment-6223868
PART#1
QuoteGeorge says:April 2, 2020 at 8:43 pmLet me try to clear the air here.
I worked for a company that invested in this and I had the opportunity to visit this site.
I got to see first hand over 1KW (a one HP motor was operating with no interconnecting wires)
received at over 1km. This was using one of the smaller devices, not the big tower.
The big tower was under construction and was testing using just a few watts..
The small tower/device was running about 5KW from a AM broadcast transmitter.
This project is real and there is no magic.
The Corum's are first rate scientists and have been identified by the US government
as a national resource with their work at Airforce Cambridge.
I had the chance to talk with them at the Viziv/Texzon facility.
They are considered THE authority on Tesla's RF work and Ball Lightning by the
Russians and Americans both.
They indicated that they had full access to all the Tesla documents in Belgrade
while working with the 1st and 2nd directors and hinted there is nothing at Wright Pat.
They made it clear the work in Milford is to basically make and "extension cord"
for power and global communications with very low power and phased arrays for location.
There is no free energy nonsense. Their calm is that they discovered how to produce a
Zenneck Surface wave by illuminating the ground with RF fields at the Brewster angle.
A Zenneck wave drops off as one over the square root of the distance.
However when a load is connected to earth all the power went to the load with minor losses.
During the presentation they indicated it was much the same as using teledeltos paper.
https://en.wikipedia.org/wiki/Teledeltos
PART#2
QuoteThey showed us a laser pointer reflected off the conference room table, at the Brewster angle
there was no reflection.
But, if you looked along the edge of the table the light was very bright.
They explained the light energy was trapped along the surface of the table.
They spent 40 years trying to figure out how to do the same thing with RF.
They indicated the obstacle was the earth dirt around the tower.
Apparently the dirt was frequency sensitive and it made the Brewster angle non real and complicated.
That was when they lost me.
Some how they made a complicated Brewster angle by playing
with the phase between the vertical and horizontal parts of the local RF fields.
This somehow this made an infinite plane.
I hope some day they publish what is behind all the patents.
They did not mention anything about Schumann resonance as you have alluded to above.
They only said their wave guide was one sided just the ground and they work very hard to prevent radiation.
Their real joy was the the replication of an experiment done by Bell Labs in the mid 30s.
The Corum's were able to demonstrate that the 1930s experiment was incomplete.
http://rexresearch.com/corumzenneck/texzon.pdf
PART#3
QuoteThey replicated what Bell Labs did and then demonstrated that if the radiation was removed
by making the structure very small and the RF fields were just so for the water, a ZenneckSurface
wave could be produced.
That proved that Zenneck and Sommerfield were right back around 1910.
With Zenneck waves there are no near and far fields, just a traveling wave with very low loss.
From what I was able to get out of the presentation regarding Tesla was that they had reproduced
Tesla's Colorado Springs experiment and sent power 25 miles.
They were quite adamant that thereare no Tesla secrets and no cover ups.
Everything you need is in the existing Tesla literature.
What is not in the literature is the "how does it work".
That is in their patents and 40 years of hard labor.
One of the Corum's had a big sign in his office,Do what Tesla tells you to do and you get the same results.
Don't try to do what you think Tesla did (something like that).
There was also a working replica of one of Tesla receivers in his office.
It was the same one he used to listen to the Jovian decametric signals and hear one, two, three.
There was also a working replica of the "eagle bug" from the great seal from the US embassy in Russia.
Who knows what else they are working on...
It was a fascinating day spent at Milford, TX.
Wesley
stivep
Wesley's translation  from English into Russian:
QuoteДжордж говорит 2 апреля 2020 года в 8 43 вечера.
Позвольте мне попытаться очистить воздух здесь.
Я работал в компании, которая инвестировала в это, и у меня была возможность посетить этот сайт.
Я увидел из первых рук более 1 кВт (двигатель мощностью один л.с. работал без соединительных проводов) на расстоянии более 1 км.
Это было использование одного из небольших устройств, а не большой башни.
Большая башня строилась и тестировалась с использованием всего лишь нескольких ватт.
Небольшая башня / устройство работала на расстоянии около 5 кВт от передатчика AM-вещания. Этот проект настоящий и в нем нет магии.
«Корум» - это первоклассные ученые, и правительство США определило их как национальный ресурс для своей работы в ВВС Кембридж.
У меня была возможность поговорить с ними на объекте Визив / Тексон. Они считаются авторитетом в работе
Теслы в РФ и Ball Lightning как русскими, так и американцами.
Они указали, что имеют полный доступ ко всем документам Тесла в Белграде
во время работы с 1-м и 2-м режиссерами и намекнул, что у. Wright Pat. ничего нет
Они дали понять, что работа в Милфорде состоит в том, чтобы в основном сделать и «удлинитель»
для  глобальных коммуникаций с очень малой мощностью  и фазовыми переходами.
Там нет бессмыслицы свободной энергии
они обнаружили, как производить волну поверхности Зеннека, освещая землю <радиочастотными полями> под углом Брюстера.
Однако, когда нагрузка подключена к земле, вся мощность пошла на нагрузку с небольшими потерями
Во время презентации они указали, что это почти то же самое, что и использование бумаги для теледотов.
teledeltos paper.
QuoteОни показали нам лазерную указку, отраженную от стола в конференц-зале,
под углом Брюстера
отражения не было.
Но если вы посмотрите вдоль края стола, свет был очень ярким.
Они объяснили, что световая энергия была захвачена вдоль поверхности стола.
Они потратили 40 лет, пытаясь понять, как сделать то же самое с РФ. Они указали, что препятствием была <земляная грязь вокруг башни>
Очевидно, грязь чувствительна к частоте, и это делало угол Брюстера нереальным и сложным.
Это было, когда они
<потеряли меня.>=(Они потеряли мое внимание)
Некоторым образом они сделали сложный угол Брюстера, играя с фазой между вертикальной и горизонтальной
частями локальных радиочастотных полей.
Это каким-то образом сделало бесконечную плоскость.
Я надеюсь, что когда-нибудь они опубликуют то, что стоит за всеми патентами.
Они ничего не упоминали о резонансе Шумана, как вы упоминали выше. Они только сказали, что их волновод
был только односторонним, и они очень усердно работают, чтобы предотвратить излучение.
Их настоящей радостью было повторение эксперимента, проведенного Bell Labs в середине 30-х годов.
Корум смог продемонстрировать, что эксперимент 1930-х годов был неполным.
QuoteОни повторили то, что сделали Bell Labs, а затем продемонстрировали, что, если излучение было удалено,
сделав структуру очень маленькой, а радиочастотные поля были точно такими же, как для воды,
то можно было бы создать волну Zenneck
Это доказало, что Zenneck и Sommerfield были правильны обратный приблизительно в 1910
С волнами Ценнека нет ближних и дальних полей, только бегущая волна с очень малыми потерями.
Из того, что я смог извлечь из презентации, касающейся Теслы, я узнал, что они воспроизвели эксперимент
Теслы в Колорадо-Спрингс и отправили мощность в 25 миль. (40.2336 km).
Они были совершенно непреклонны в том, что нет секретов Теслы и нет прикрытий. Все, что вам нужно,
в существующей литературе Тесла. В литературе нет «как это работает». Вот в их патентах и 40 лет каторжных работ.
У одного из Корумов был большой знак в его офисе: делай то, что Тесла говорит тебе делать, и ты получаешь те же результаты.
Не пытайтесь делать то, что, по вашему мнению, сделал Тесла (что-то подобное). В его офисе была также рабочая копия одного из приемников Теслы.
Это был тот же самый, который он использовал, чтобы слушать декаметрические сигналы
Юпитера и слышать один, два, три. Была также рабочая копия «орлиного жука» с большой печати посольства США в России.
Кто знает, над чем еще они работают ... Это был восхитительный день, проведенный в Милфорде, Техас.
Wesley
stivep
*Thank you my friend.*
speedy 125 has gave us new piece of information.
Some news about NMR , I was find something ,
(... Actual evidence of nuclear electric resonance has now been discovered by accident in a lab at the University of New South Wales (UNSW) in Australia,
thanks to faulty equipment.
The breakthrough gives scientists a new level of control over nuclei, and could seriously speed up the development of quantum computers. ... )
https://www.sciencealert.com/in-an-accidental-discovery-australian-engineers-solve-58-year-old-quantum-mystery?fbclid=IwAR1TFgv7GLiBo9HcZoNaskzjmLof3uWhc9aFf0e548CHmH7eMgSGGPIv7VA
also,
Article
Published: 11 March 2020
Coherent electrical control of a single high-spin nucleus in silicon
https://www.nature.com/articles/s41586-020-2057-7
Wesley
#3171: yes,nice optimation potential for silicon nano-grain-dots as ink for surface printing !
I would as research tool combine with
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=6&ND=3&adjacent=true&locale=en_EP&FT=D&date=19890201&CC=DD&NR=264511A1&KC=A1
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=11&ND=3&adjacent=true&locale=en_EP&FT=D&date=19870603&CC=DD&NR=246367A5&KC=A5
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=13&ND=3&adjacent=true&locale=en_EP&FT
=D&date=19860730&CC=DD&NR=237897A5&KC=A5
I mean Stockholm Nobelprize-work level ,Manfred Alexander Gregor his discoveries !
What me wonders about the Viziv technology is their fixation ,as tower !
The russian AIRHES idea as flowing ballons/zeppelins/cigars would giving beside water,electric energy also a
emitting and receiving body(great absorption and reflecting field) for telecommunication !Thin kevlar film ?
https://airhes.com/
https://newatlas.com/air-hes-cloud-power-clean-water-energy-vapor/33512/
Inflatable -cool earth- like concepts ?  https://www.coolearthsolar.com/
Remembers me also Otto von Traun and Prof.Herman Plauson their ballon concept !
http://www.mareasistemi.com/DIDATTICA%2027/Hermann%20Plauson%20%20Conversion%20of%20Atmospheric%20Electricity%20%28Articles%20&%20patents%29.htm
Body with solar dot ink ?
And 24/365 topic Owen P. Barker solar cell use for telecommunication US5009243   https://patents.google.com/patent/US5009243A/en
r2fpl
