stivep
this file in RAR  is asking for password
Wesley
Void
Quote from: stivep on April 28, 2020, 01:44:56 PM
Wesley
Dear Wesley. The password for the RAR file is corum.
All the best...
magnetstoo
Wesley...I got this antennae system to operate into transformers, a small 240 to 24v & smaller 120 to (12v + 12v)....they connected in reverse but they both can light up 40w of bulb power pretty good.Im including the schem and pic.I tried a microwave transformer - connected forward- but had little luck,will try again later.------Have you ever tried to align a satellite dish using only a hand compass? I have.And that is what this system is akin to.
magnetstoo
That 680uF cap can be bypassed as I am not sure that is how was connected now---it will run without it but less output. But my system has just dropped out since testing larger transformers.I put the 240v TFMR back on and it blew the diode (somehow). Now I am having other problems as it will not link-up nor respond to movement.I have had the whole thing apart starting from scratch---It ran for a couple seconds with the 14 watt then that was it--blew that diode,could be the OPA amp but its power lights are on.
magnetstoo
It blew the OPA541 amp and the diode,------I replaced both then it blew another diode...again replaced .But it still will not even try to run through a transformer,nothing.it shows the current moving through but it will not even dim the bulb.Ive checked everything over and over,so its back to basics... Also,not shown earlier ,the OPA amp DOES require an external gnd at the output side else it will not tune in this system.Im including a "basic" system setup which worked just to give an idea what Im doing.The transformers was an afterthought.
