0 Members and 28 Guests are viewing this topic.
PolaczekCebulaczek
QuotePersonally I do not believe that what you describe makes sense or is possible, but I am not knocking what you are doing, I just don't see it, the earth rotates with it's magnetic field and IMO it cannot be tapped as you suggest, at the same time i do not expect I can convince you of that.
I can however see a lot going on that I have discovered that Hendershot lines up with, a lot of aetheric principles, at least 7 things without looking too hard.
But it does not hurt to incorporate my idea whatever you might believe, most are electrically neutral.
That is not to say I don't believe the earth magnetic field plays no part, I think it does, just not as a means of energy generation.
If you show me what you are looking to do I can give you pointers, things you could try.
At any rate, there is not chance that most devices have a "conventional" explanation as they show signs of aetheric energy, current that does not shock, different colour of illumination, arcing at low voltage, thermal and magnetic anomalies and other weird stuff.  indeed, I am not sure this does not apply to Hendershot as well, but it applies to many devices.  indeed a number of Free Energy devices have Antigravity as a side effect.
Logged
I'm not sure if my theory is correct, but i will try and see what would happened, there should be "something" because of third newton law (does third newton law works for magnetic fields too?) but what and how many I don't know. I just don't want to humiliate myself because this could be some stupid BS and lack of physics knowledge on me side lol. plus the language barrier so I will explain more and make some diagrams or even crude animation if I got the good results. The core idea is to push against earth mag field in some tricky way.
Anyways, the eather stuff could be related to magnetic fields, the bigger/wider the field the better, like in your transformer idea, so you could be right, once i made all sort of coil configurations and there were effects that i could not understand like primary bifilar canceling magnetic field coil(non inductive) that lights LED's on normal winded secondary while 0 current or voltage is shown on meter, some say that its capacitance effects but I'm not sure... same goes for coil made out of coil (wind coil on a thick insulated wire, this wire serves as core and then twist/wind this core on plastic pipe), in some cases i could power many leds with 0 currents on multimeter, yet cant charge capacitors with this, funny stuff.
aether22
Quote from: PolaczekCebulaczek on July 24, 2018, 07:34:29 AM
Funny, you just mentioned 2 major aether hacking methods...
So, the bifilar coil many have observed creates a beam out the center.  By many people entierly independent of my efforts!
I have heard people talk about this!
What I have discovered, and really the outer coil in my inductor could be replaced with self cancelling bifilar, either totally cancelled or mostly...
What occurs is that if you induce aetheric energy (there is aetheric energy induced in electromagnetic induction, but normally not enough)  in 2 opposite directions, the opposing flows create collisions, and this creates aetheric turbulence, and this creates pressure...
And this pressure squeezes and focus energy inside the bifilar coil, and if there is another coil inside of that it can gain a lot of aetheric energy, the more you create density on the center of the coil the more the center radiates energy back out, this is because you raised the pressure of the aether so all activity disturbs a thicker more lively aether.
But, the short version is that it makes aetheric energy increase in the center.
Actually ideally a spark gap, or something highly energetic could be in the center...  Maybe a magnet, or a capacitor.  But something, maybe a resistor or light bulb.
However I suggested separate coils because while the EMF and aetheric EMF (yes, there is an aetheric analog of everything) in these coils will still work, it also creates a magnetic N pole in the center, and I have found this kind of thing can create aetheric magnetic monopoles!!  Not sure regular ones exist, but they exist aetherically!
Ok, now about the coil made of a coil...
So the first coil that I felt energy from after 17 years was a coil made of wire that was coiled around a central wire.
I could feel this coil issue and energy, even after it was disconnected the energy would persist, then I found if I made it asymmetric it would work without being connected to anything electrical, it just needs needs some bias.
forest
I read comments below last Panov video. He state Ruslan Dębice can only light something like 100w bulb. Prawdopodobnie czegoś brakuje 😋 albo już ktoś dotarł do Panova i wytłumaczył mi co i jak..... Kiedy wreszcie zrozumiecie że urządzenie musi przedstawiać realną wartość dla ludzkości np pozwolić na ogrzewanie domu bez kosztów eksploatacyjnych a przy tym nie może być ani cienia wątpliwości że nie pobiera lewego prądu z sieci elektroenergetycznej. Do tego kwestie testòwt , zabezpieczeń, bezpieczeństwa , atestówa, bezpieczeństwast, instrukcji obsługi serwisu części itd. Bez wsparcia lokalnego rządu to sie nie uda.
Hoppy
Quote from: forest on July 25, 2018, 05:31:49 AM
Rough Google translation: Probably something is missing 😋 or someone has already reached Panov and explained to me what and how ..... When you finally understand that the device must represent a real value for humanity, for example, allow heating your home without operating costs and at the same time there can be no doubt that it does not charge the left electricity from the power grid.
This includes test, security, safety, approval, security, parts service instructions, etc. Without the support of the local government, it will not work.
Hmm, how do we construe the meaning of the highlighted text??
forest
Quote from: Hoppy on July 25, 2018, 06:42:12 AM
Well does it or doesn't it use stray current from the grid?? Maybe this is what Wesley needs to establish during his visit to Latvia.
Panov said it can only give 100W and only when ground cable Has correct lenght. Sorry this tablet force je to wrote in Polish
