stivep
stivep
PART#2
Translation of article from above:
On the physical effects arising from the
outflow of high-pressure water
Quotevapor from a spiral channel formed
by a steel pipe wound on a conical mandrel
_______________________
I.N. Stepanov ∗
Abstract — The reason that prompted the publication of this article was the work of
I.A. Melnik
about the appearance of rotating masses in the vicinity
unidentified field called field rotation, which affects the half-life
radioactive isotopes
... This work is
the closest analogue of the experiment carried out in 1981, according to the idea of ​​the famous scientist A.F. Okhatrina.
The scheme of the experiment is presented and the goal of the task is stated.
Given a description of the parts of the equipment used and devices.
The results of the measurements are given, presented in graphical form, and
also information about the pathogenic effects on experimenters who were near the working
installation.
I
n the early 80s. A.F. Okhatrin, on the basis of his theoretical studies, suggested that when high-pressure
water vapor is passed through a metal tube wound on a conical frame,
when the vapor flows into the atmosphere, i.e. in the vicinity of the apex of
the conical spiral, ionizing radiation is possible.
The idea was so interesting that it was decided to test this assumption experimentally
A 25-litre
steam generator  with a built-in 4 kW was used as a .receiver
The thickness of the receiver's walls allowed to get overheated steam with pressure up to 16 atm.
The spiral channel thin-walled steel tube Ø16х1 in length of 20 m was wound on a circle from 16 mm of plywood
in diameter of 70 mm, laying on a horizontal plane, "turn by turn"
When the winding was completed, a flat spiral was obtained, consisting of 20 turns, the largest of which had a diameter of 800 mm,
the diameter of the small turn was 100 mm.
After being removed from the mandrel, the flat spiral was additionally stretched along the axis by about 1 meter so that, as a result,
the generatrix of the resulting funnel acquired a shape close to an exponential, (Spiral cone)- funnel.
In order to eliminate possible distortions of the obtained spatial shape of the channel,
during the experiments, a light supporting structure was made for the spiral, which
corresponded to the final shape of the envelope.
This frame made it possible to position the funnel in such a way that its symmetry axis
lay in the horizontal plane, the rotation is right
The block diagram of the experimental setup is shown
in Fig. 1.
The outlet pipe of the
steam generator through the valve was connected with a hose to the beginning of the
spiral (turn of the largest diameter).
Steam flowed along the spiral channel accelerated, so that the maximum flow velocity was observed
at the end of the tube with free flow of steam into the atmosphere near the spiral axis
.A.F. Okhatrin assumed that in the process of accelerating the flow of steam in a spiral and
its outflow into the atmosphere, an electric current and ionizing radiation should appear in
the spiral near the apex of the cone
Therefore, in the region of the end section of the tube on the axis of the spiral, an ionizing radiation
counter STS-6 was placed, connected through a preamplifier to a
frequency meter Ch-3-33,
and a DC voltmeter was connected to the ends of the tube
The experiment was carried out as follows.
When voltage was applied to the heater, the STS-6 counter was started.
He showed a natural background of radiation at 13 micro-roentgen / hour,
and a voltmeter - zero potential difference at the ends of the tube
After the steam generator heated the water and the superheated steam pressure reached 16 atm,
the valve was opened and steam entered the spiral channel.
From that moment on, the STS-6 meter began to record a gradually increasing number of pulses,
and the voltmeter - the emergence of a potential difference with positive polarity at the beginning of the tube.
________________
Approximately 105 seconds after the beginning of the steam outflow from the tube, the number of
pulses recorded by the counter reached a maximum of 11 milliroentgens / hour, which exceeded the
natural radioactive background by almost three orders of magnitude, and after that it began to gradually decrease.
The readings of the voltmeter, whose numerical values reached a maximum of 2 volts, behaved in a similar way.
The results of measurements of the number of pulses recorded by the STS6 counter during the spiral flow of steam are shown in Fig. 2.
By the end of the experiment, which lasted 195 seconds, the pressure in the steam
generator became equal to atmospheric pressure and the outflow of steam stopped.
By this time, the STS-6 counter readings returned to a level of 13 microroentgens / hour,
and the voltage at the ends of the coil became zero
problem #3.
In addition, it should be added that the  installation during  experiment
- had a clearly pathogenic effect on the experimenters when in close proximity to the device.
-pulsed headaches,
-dry mouth,
-mild nausea,and loss of energy were felt.
After the steam was completely out from the device
in about one hour later
all the negative effect on the experimenters bodies ceased.
end of translation
the conclusions will be  in the next  comments
Wesley
stivep
While looking  in the internet for the
Author:  Alexander Shishkin
mentioned by   Martin Fleischmann Memorial Project
                    in the video   https://www.youtube.com/watch?v=gcF-KSLIAWs
                    Video title: A New Type of Penetrating Radiation (Alexander Shishkin)
                    1,719 views                   •Feb 8, 2019
who in •Oct 5, 2018 made video  having only 204 views
                      Title of video:   Alexander Shishkin - Part of 25th Sochi CNT&BL Presentation
                      https://www.youtube.com/watch?v=68BOYCbtcwc
__________________________
I went across  very interesting  list of Andrea Rossi
https://e-catworld.com/display-posts/
The purpose of the site is to provide a place for news, information, analysis and discussion of all things
pertaining to Andrea Rossi's Energy Catalyzer invention which holds the promise of providing a much
cheaper, cleaner and more efficient means of power production than we have ever seen.
surprisingly this list is still active
with the latest  news:First Third Party Test Successful, Certifying Agency Testing Scheduled (9/24/2020)
Note: All of said above in the last  few posts  starting  from
         https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg551033/#msg551033
         is talking about  LENR .
Wesley
stivep
PART#5
continuation from Part#4
Analysis of problem#3 listed in PART#2
